SOURCE: Noise vibrations in dehumidifer
sounds like a sealed system issue it has a 5 yr. warrenty on the sealed system, cost to repair might mean an new one instead
SOURCE: culligan gold series 9'' water softener has a constant error code
It has been my experience that when you have made several attempts to correct the error codes as directed in the owners manual, you most likely have a defective controller.
You should contact Cuno and locate a service representative near you to see about getting the controller replaced.
sanray
SOURCE: I have a culligan,gold series water softener.The
call your culligan service department. they will tell you what to look for.
SOURCE: My Magnavox plasma screen tv, model number:
You either have a cold solder joint in your horizontal deflection circuits or your or in your horizontal output circuit. please be careful due to the fly-back transformer still holds power even unplugged until you discharge it.( ground it out). Hope this helps.
SOURCE: Culligan 01010091 (mark 89) softener will not auto
clean the drainage filter then it will work correctly again
