Question about Jura Capresso Coffee Makers & Espresso Machines
Hello, i have a Jura X9 that is not bringing up any error codes but is stuck in the "machine heating up" mode and nothing changes it. 2 years ago i replaced the steam boiler sensor. Can you help?
    Top Expert:
  • Jura Capresso Master
  • 62,130 Answers
Sadly no we can not
Posted on Mar 07, 2019
SOURCE:
  • 641 Answers
SOURCE: error codes for indesit front load washing machines
The F002 error codes relates to a motor problem. Do you know if the motor spins ?
Posted on Aug 16, 2007
Inky
  • 705 Answers
SOURCE: printer dfx8500
The DFX-8500 uses a series of beeps to identify errors and error 6 relates to carriage load measurement. This error causes an auto power off after 12 seconds.
Parts that can effect this error are:
PW Sensor - defective
CR Motor - Defective
CR Encoder sensor - defective
Hope this helps
Posted on Jul 16, 2008
SOURCE: Saeco Primea Cappuccino Ring--stuck on "boiler filling" mode!
Hello, I had the same problem, therefore the machine has gone to a repair centre. The problem is caused by a mechanical switch in the machine, that doesn't work properly. To repair it you've to open the machine completely, but that’s not easy. Because there is nothing broken you’ll should have warranty because it is a production failure. The solution in my case was to heat up the switch and push it a little together so that the contact works properly. It is the switch that you hear when you turn on the machine.
Posted on Oct 30, 2008
  • 143 Answers
SOURCE: No steam on Capresso Impressa S8
Most likely problem is over temp cut out switch. Small diode attached to the boiler to prevent damage during boil dry, or fault in the heating element itself. Difficult machines to repair and best handled by a service technician.
Posted on Sep 14, 2009
SOURCE: My dispay on my jura E8 says error 5.
Has anyone found a place to service a Jura Capresso Impressa E9 in North Carolina?
Posted on Jan 05, 2010
My jura x9 says rinse fill
This happens when the machine is priming the thermoblocks(heaters) the machine is not registering water flow through the machine.blockage in water tank? pump not running? a thermoblock scaled up(blocked). first check the 2 flow meters in the machine located under the water tank. one of these may be defective or just stuck,
Aug 29, 2014 | Jura Impressa X9 Espresso Machine
Jura x9 water tank fill rinse
So what's the question?
https://www.capresso.com/customer-care-instruction-booklets.shtml
Jura impressa x9 classic.
this problem is normally due to the flow meter not sensing water flow through the machine. possible causes are 1,lime scale in the thermoblock this may need replacing. 2, the pump has failed also may need replacing. 3. the flow meter itself is stuck , this can be dismantled and cleaned, if not then replacement is required. 4. a simple blockage from the water tank to the inlet . not a job for the novice..
Mar 30, 2014 | Jura Impressa X9 Espresso Machine
Jura X9 coffee machine is stuck in the heating up mode. How do I fix it?
Either there is issue with the Sensor or the Thermoblock. you'll have to replace either of these.
Oct 02, 2013 | Jura Capresso Impressa X7 Espresso Machine
Coffee Makers & Espresso Machines Logo
Top Jura Capresso Coffee Makers & Espresso Machines Experts
markybean
Level 1 Expert
Colin Stickland
Colin Stickland
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
