Will also like to know if I can update firmware without using CF card
If you need any kind of repair or installation services in regard to PCs or laptops, or any PC tune ups then you can get in touch with Geek Squad Support, as we offer the best services through the hands of professionally trained agents and provide 24*7 support & assistance to our customers.
https://geeksquadssupport.com/webroot-geek-squad
Have no idea
SOURCE: Invalid Engine Code
This is actually a Lexmark printer, so what I'm quoting is a Lexmark sol. turn off machine hold down returnand go buttons turn on printer hold until performing test shows and let go of buttons it will go to a service mode ( instead of saying ready) got to printer set up hit select button go to engine 1,2 or 3 try each one ( hit select to go into that perticular number) what you are looking for is a number that has an * next to it. Use the arrow keys to scroll. most likely it changed the setting so go and look for that number w/the * and hit select when you see it.
SOURCE: Firmware Problem !
here is an older version of the magicolor 5430DL Firmware:
version 2.06
ftp://ftp.minolta-qms.com/pub/cts/out_going/other/5430_206.zip
Best Regards
Thorsten
SOURCE: Reverse Firmware Upgrade
http://www.fixyourownprinter.com/forums/printer/56368
There are two different print engines used in the CLP-300. One for
2006, and a different one starting in 2007. I have the older 2006
printer, and the current firmware is only for the new 2007+ print
engine.
I talked to Samsung support here in Korea and fixed the
problem. They sent me to their special tech support website at
www.1479.co.kr (only in Korean) and I was able to download an older
version of the firmware which restored my printing ability.
The latest version of firmware that worked with my printer was found in this post: http://www.bassmania.co.kr
Download
the two files at the top, then extract the archive. Drag-n-drop the
correct firmware file onto "usblist2.exe" and the printer will be
flashed with the firmware (must be connected via USB if you're using
the CLP-300N model).
SOURCE: New 4GB CF card for E5400, camera gives 'out of memory' message
So far as I am aware, the 5400 will support only up to 2GB cards. As to the firmware upgrade you mention, I don't recall that that has any bearing on the max. card capacity; but it's worth doing for the RAW format support (for me, at least). Cheers and good shooting. Davo, Tas.
