SOURCE: 2001 lincolon fuel door release push button
First open glove box and look in the left top corner and you should see a black valet button. Press this then see if the fuel door release works then. If you still need the replacement get the part number from your local Lincoln or Ford dealer
SOURCE: Kenmore 600 series dryer, has
Hello, I just repaired the exact same problem a few days ago. The problem is either your even heat board or the motor relay. There are two pink wires with black tracer on the motor relay on the right side. You should be getting a reading of 48 VDC when the push-to- start button is pushed. If you don't get 48 VDC, then you need to change out the even heat board. Hope this helps! Chances are, it's just the motor relay and should cost you under $20 to fix. If you have a technician look at it, then he should charge you under $100. Thank you.
SOURCE: My trunk won't open, I
There are 3 phases to fixing your car's trunk lid release problem.
Phase 1: First check the fuse - once you know that's OK, then proceed to phase 2 (below).
The fuse for the trunk lock is
the bcm (pwr) 15A fuse in the instrument panel fuse box (behind panel at drivers right foot)
Check that fuse, as it is the power supply for the button on the dash that sends power to the actuator in the trunk.
Phase 2: Get the trunk open (without taking it to the dealership).
If you have remote keyless entry to the trunk, you could try that - but with the actuator
dead/dying, it shouldn't work.
Here are a couple of ideas to try to enter trunk while (a) actuator isn't working, and (b) all
valet lockout features (designed to deny valets access to the trunk) are in the "Lock" position:
There is the lock cylinder, which you stated is not functioning - put the key in, and it doesn't
turn. Just to be sure, consider: lubricate key with Graphite lock-type lubricant, and retry.
The trunk has 2 valet safetys...the locking rear seats which require access to the trunk to unlock, and then there is a valet switch in the trunk that locks the button on the dash from working to keep valet parking attendants out of the trunk. That may be in the lock position.
You can try accessing the center area of the fold down rear seat and see if you can unhinge the rear seat from there. Maybe reach in with your hand, or an extension-type tool.
there may be a way to fold the hinge away from the seat back so it can be removed from the hinge and give you access to the safety latch in the trunk and open it that way (white handle in trunk).
The white-handled safety latch release is desiged to prevent accidentally trapping children, and
if you can pull it with your extending-type or grasping-type tool, the trunk will open whether or
not the actuator motor is working.
Phase 3: Replace the Problem part.
Your failed part may be either (1) Trunk Release Relay, or (2) Trunk Lock Release Switch
My Satrun ION manual doesn't cover either of these parts, and the online parts houses, e.g.
http://www.rockauto.com/catalog/x,carcode,1431624,pgname,Electrical-Switch%2B%2526%252338%253B%2BRelay,a,search.yahoo.com%2BSearch%2Bfor%2B2004%2BSATURN
fail to provide instructions. One of those times a mechanic has to t=rely on his/her native
handiness and/or experience.
To identify which of these parts is bad, locae the Trunk Release Relay (call your dealer parts
dept. for helpful tips on finding it), then operate the dashboard trunk release button with your
ear close tothe relay - if it makes a noise, the problem is the Trunk Lock Release Switch in
the trunk lid, otherwise its the relay.
SOURCE: I have a Dell Demension
if your PC have restart button then open your PC and check the power cable slots and change them into a reset mode removing reset cable to reset slots and attach to power slot. Then you can power your pC with reset button. If you can open front case then you can outside the button .
SOURCE: Push start button dryer runs 1 second. Hold start
I have found that the switch activated by the door close or turns on the interior light when open on is likely the problem. You may notice that if the door is open and you push the start button, it will buzz. So if the door is closed and you get this buzz when pushing the start button, there is a problem with the door switch. The start button "thinks" the door is open, and therefore not start. The defective door switch needs to be replaced. At least highly likely.
