Refrigerators Logo
G
Glenn York Posted on Mar 07, 2019
Water is accumulating under the sliding tray in the CoolSelect Pantry.How can this be fixed?
1 Related Answer
Anonymous
  • 43501 Answers
  • Posted on May 26, 2011
SOURCE: Water under the CoolSelect Pantry.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Cool Select Pantry, to relocate per manual instructions, doesn't slide all the way in.
Cool select Pantry
To remove the pantry - Pull the pantry out to full extension. Tilt up the front side of pantry and pull straight out.
To relocate the pantry - Push the rails to the back of the Refrigerator. Place the drawer onto the rails and slide the pantry back until it is in place.
before install they ask to push the rails to the back of the refrigerator
should be no problem
Cleaning the base under the slide out tray.
pull tray part way out then lift up Cheers
heatman101
Water collecting under Cool Select pantry. 3 servicemen attempted to fix it--to no avail. Now water is frozen at front of pantry and still pooled in back. Refrigerator is less than 2 years old. ALSO, a...
Do you have an automatic ice maker/dispenser? If yes check and/or replace same, and also checkfor broken pipes. you may have to slide out fridge to do so....be careful as piping or wiring my also be tangled. look for leaks.Repair as may be necessary. You might also take offthe filter,be sure water is shut off, inject food coloring into the water line,reconnect everything and partially open water and look for colored water which should lead to the leak.
No icemaker? orven as last resort with icemaker, check for hidden built up frost, sometimes a tricky deal and/or turn off fridge completely and let it come to room temp (defrost the whole thing) and see what happens. A collection of new water will inticate that it was over frosted. Probably from too many door openings and closings. Be prepared with cleanup sponges and such! Note: store food properly while defrosting!
1helpful
2answers
I have water standing below the veg. trays, not sure where it is coming. How do I find the drain lines.
The water comes from the accumulated moisture. Just
clean the drain at the back of the veg tray. Get you veg. tray out so you will find the drain.
Water accumulation under vegetable drawer model KTRS22M
its the problem of the compressor present in your fridge... if its malfunctioning, then water wil accumulate under the vegetable tray
Top Refrigerators Experts
ZJ Limited
ZJ Limited
john h
