Car Audio & Video Logo
J
James A Myers Posted on Mar 07, 2019
Can ddx 395 display maps from my phone? If so, how?
Pro-Form Crosswalk 395 - Incline goes up and down with no tread movement. Calibration doesn't work - only on display.
test the main board, with the output voltage from board for input voltage motor. If there are NOT voltage the board is faulty.replace see the block diagram, how the main boad control about 80% of the machine motion.
God bless you
I just installed a oem navigation in my 08 wrx,every thingthing works but the sat nav.there is a plug where i dont know where it goes?
do you have the external CD Reader attached? it requires this to supply the map information for the GPS to work
1helpful
Plastic gears broken on dremel 395
Hello. Call Dremel technicians directly for both parts and service. If you want to repair it your self let them know and they will ship you the parts you require
Phone:
1-800-437-3635
toll free:
1-262-554-1390
(7am-6pm CT Mon-Fri)
Look i have a phoenix digital PD 395 and when i
some amps require more than 500 milliamps to keep it "turned on" most head units put out half of that ,bosch relay inline from deck to amp turn on post should do it this will give the amp a full 12 volts to turn on and stay on . first try to hit the maps with a jumper with 12volts fused , see it it stays on
7helpful
I have a sanyo dvd player dwm-395. how do i unlock it w/o remot
For the DVM-390 model, I believe this solution should work on the DVM-395 model - Push and hold down the Open/Close button until "UN-LOC" appears on the FL display (or "Disc Tray Unlocked" appears on the TV screen).
Can't get a map to display
Nokia have released an update for their maps application . This should hopefully resolve your issue
IS IT POSSIBLE TO UPGRADE DDX 6039 TO DDX 7039?
With this post i presume you are on about in dash monitors!
the DDX6039 and DDX7039 will connect in the same way.
however the remotes are different, the 6039 uses remote rc-dv430 and the 7039 uses an rc dv330.
Password Reset Help
During code request:
Point the remote control to the screen and input these numers (fast as you can).
55222277
ps.
You will not see any change on the display untill you enter tha last digit.
LET ME KNOW IF IT WORK thank you
2answers
Need the codes
i need a code to unlock a ddx-7015
Top Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
