The problem is a defective defrost system. The defrost system comprises defrost thermostat, heater, defrost control and fan. The parts that fail more commonly are thermostat and heater. Both parts are located behind freezer firewall and tested reading impedance with a multimeter.
You have either a defrost timer, defrost thermostat or defrost element that is bad.Before you defrost, use an ohmmeter to check the defrost thermostat to see if it is closed. If it is , defrost and check the defrost element for continuity. If it has verry little resistance , you have a bad defrost timer.
There are three chances for not getting freeze. Defrost activate quickly, due to: 1. Thermostat malfunction- Replace it. Thermostat setting. - Must be -5 degree or less than that. 2. Defrost timer for malfunction. If so, replace it. 3. Freezer heater malfunction.- Replace it.3. System chocked or short of gas. Check with run amps. Solution: If system chocked, release all gas and replace filter drier. Flush out the system, vacuum and recharge gas. If short of gas, leak test and arrest it. Vacuum and do gas charging. Thanks.
Your defrost timer,defrost thermostat and defrost heater need to be checked. The heater and thermostat are inside the freezer behind the back freezer panel. The timer is underneath the refrigerator either the left front or right rear.
The most likely cause is that the defrost system is not working. After about a week it builds up with enough frost to stop the cold air from getting to the refrigerator section. The most common problem is the defrost timer, defrost heater or defrost thermostat.
The fridge gets its cold air from the freezer through a vent
between the freezer and fridge.The fan in the freezer blows air through
it.There is a flap you adjust with the
fridge temp. control. Make sure it's opening and closing when you adjust the
fridge temp ..
