Question about LG Tablets & eReaders
Lg lk460 tablet wont charge when device is powered on.
Whenever the tablet is on it dosent recieve any charge but it does charge when its off. Also every time it turns on a firmware update tries to download. Ive tried leaving the tablet on the charger and finishing the update but it never goes above 0%. I can pretty easily by pass this by holding power an volume down, i dont want to have to do that everytime though. Ive tried manually updating but it says there is no update. also my volume up key dosent work so any solutions involving it wont work for me. Pls help
  • LG Master
  • 26,395 Answers
You either need a new one, or you need to fix the volume button so you can do a hard reset. Can you reset it via a computer like you can with an iPad I wonder?
https://www.google.com/search?q=Lg+lk460+tablet+wont+charge+when+device+is+powered+on
Posted on Mar 07, 2019
SOURCE:
pink123
SOURCE: w300 WONT TURN ON WONT CHARGE!
i happen to me you need to find a friend or a family that has the same phone that you have and that your problem solve!
Posted on Dec 28, 2007
SOURCE: RCA MC5104 Lyra will not
After trying every possible scenerio to solve the problem, I brought the player back to the retailer. After hearing my story replaced no problem. Replacement works perfectly.
Posted on Dec 31, 2008
SOURCE: I downloaded updates on my iPhone 3G, did a reset
Held the home button and power button for 10sec, released the power button after apple icon appeared and continued to hold the home button until the USB cable icon appeared (this action prepares the iPhone for Factory reset), now connect iPhone to iTunes and follow the prompts! Note: when you restore your iPhone everything will be deleted to Factory Settings and you will only be able to retrieve your settings to the most recent back up you have stored, any data not stored in iTunes, example: (SMS, appointments in Calender), will be lost!
Posted on Sep 03, 2009
giao_mai
SOURCE: My Samsung Galaxy Tab won't turn on, even though battery is full. What's the problem?
hi did you fix your problem?
Posted on Mar 06, 2013
cougar123
  • 77 Answers
SOURCE: the 7 inch tablet when you turn it on shows the 2 dogs then goes to rca logo and nothing else. tried to reset by holding power & volume button at same time, did not work
contact vendor mfg - shoulds be under warranty
Posted on Jul 11, 2014
How can I bypass a Google account on a lg lk460 tablet
If it's telling you the tablet is locked and requesting Google credentials to continue, you can't bypass that.
That's an anti-theft feature. You'll have to have the owner of the last Google account who logged into the tablet log into it to continue.
May 10, 2018 | LG Tablets & eReaders
My Visual Land Prestige Pro Android tablet will not charge
Visual Land Prestige Pro 7D Repair - iFixit
https://www.ifixit.com/Device/Visual_Land_Prestige_Pro_7D
iFixitVisual Land Prestige Pro 7D troubleshooting, repair, and service manuals. ... Tablet is fully charged but it won't stay on ... Why won't my device charge? ... The 7D runs on a newer Android 4.1 Jelly Bean, and has 1GB of RAM, compared to the ...
prestige 7 wont power on - Tabletroms.com
www.tabletroms.com > ... > Visual Land Tablets > Prestige 7
Sep 7, 2012 - 9 posts - ‎2 authors
I found this forum from searching about the prestige 7 and watching the videos ... It showed the charging animation for a few mins and then went off. ... I'd like to figure out what the problem is as I quite like the tablet and it was half .... prestige pro 7d won'tturn on. ,. visual land 8q has power but will not turn on. prestige 10D wont turn on after charging help!
Mar 23, 2014
Visual Land Prestige 10 charging issue
Jan 2, 2014
Ack... Help... Major Battery Issue!!!
Jan 24, 2013
Power Port Charging Issue
Jun 12, 2012
More results from www.tabletroms.com
Jan 07, 2016 | Visual Land Prestige Pro 10D 16 GB Wi-Fi...
My tablet it dosent want to charge
try different USB to micro cord from charger to tablet....
Mar 02, 2015 | Tablets & eReaders
MY TABLET IS FULLY CHARGED AND DOSENT WANT TO TURN ON WHAT DO I DO.
If its an android device. Hold the volume and power down button down at the same time. I've done this to reset a working tablet. It might work for you
Feb 22, 2015 | FUHU Nabi 2 Android 4.0 Tablet for...
My LG slate tablet wont turn on
my son charged mine with the car charger for higher voltage charge and its working fine now
Dec 22, 2013 | LG 8.9" 32GB G-Slate Tablet
Nabi will not charge .have new charger
Whenever you plug in your Nabi 2 tablet to charge, The tablet will boot up. Whenever tablet boots up, turn it off and leave it charging for a good 4 to 6 hours. That should charge it.
Aug 12, 2013 | Nabi 2
My pandigital tablet dont wanna charge
USB Connections
All tablets connect to your computer using a USB cable.
Once connected, the device should charge as long as the computer recognizes it.
Look for manufacturer-specific software to launch once you plug your tablet into your computer; if this software fails to launch, it's likely that your computer hasn't detected the device and won't charge it.
Try a second USB cable, if available, or plug the USB cable into a different port.
If the device doesn't charge in either port, replace the USB cable.
AC Adapters
Some tablets are sold with an accompanying AC power adapter, though these accessories are often optional.
Try plugging your tablet into its AC power connector in the event that its USB cable isn't functioning.
Also check different wall outlets in case the outlet you are plugging your tablet into is defective.
If the device fails to charge in different outlets, the AC adapter may be faulty.
Reboot Like any device with an operating system a computer, a mobile phone or an MP3 player tablet computers can freeze from time to time.
When a computer freezes, you can reboot or restart it to get the operating system working properly again.
This is true of tablets too, but rebooting these systems can be a little tricky.
Check the manufacturer's website for specific instructions to restart your system.
Putting the tablet to sleep and waking it up doesn't clear its memory look instead for the buttons for a "reset," which are different for every brand.
This may clear up any recent malfunctions, like freezing apps or charging issues.
Restore
Just like a computer, tablets sometimes need to be restored to their original state to overcome technical issues like charging problems.
Again, the process of restoring your tablet to its factory default differs from model to model and from brand to brand.
Check the manual or the manufacturer's website for specific instructions, but as a general rule: plug the tablet into your computer using the provided USB cable.
Wait for the appropriate software to load and then look for a "Restore" option.
Follow the onscreen prompts to restore the device.
Aug 05, 2013 | Tablets & eReaders
Recieved a brand new netbook today, booted it up connected to net, logged off net, cursor then froze. Had to turn off netbook with power button but now it wont power up
Try to remove battery.
Putt baterry back, leave at least 5 hours to charge, and after thi try to start your notebook.
Mar 03, 2010 | Tablets & eReaders
Tablets & eReaders Logo
Top LG Tablets & eReaders Experts
 Mike M
Mike M
gbob59
Marvin
Marvin
Are you a LG Tablet and eReader Expert? Answer questions, earn points and help others
