Question about Nortel Meridian M7208 Corded Phone
Program caller ID on M7208 Meridian/Norstar PBX phone
    Top Expert:
  • Nortel Master
  • 51,327 Answers
Subscribe to the service provided by your carrier. It is not a programmable option.
Posted on Mar 06, 2019
4 Suggested Answers
SOURCE:
cnavarro
  • 2460 Answers
SOURCE: Nortel Meridian Norstar-Plus Compact ICS with #7310 phones.
I'm pretty sure CID is automatic on a CICS....IF you have a CID trunk card. You might want to post the part number on the face of the trunk and we'll see if it's the proper one.
Carl
Posted on Jan 08, 2009
  • 4 Answers
SOURCE: How do you set up caller ID on a Norstar M7208
There are a few other things you need before it will just work on your phones. You need to get Caller-Id activated by your carrier on each of the 4 lines. You also need to make sure your system has a Trunk card capable of Caller-Id. The card in your systems should be labeled CID.
After this you still need to program the lines for Caller-Id in the configuration section of programming.
Posted on Jul 30, 2009
consultel1
  • 860 Answers
SOURCE: Do the Norstar M7208 and Aastra 9120 phones
No, the M7208 is a propriatary set which requires the PBX to function, whereas the aastra phone is a stand alone set which requires a standard telephone line and a power source.
Posted on Dec 23, 2009
Why doesn't one phone in my norstar meridian m7310 phones is not displaying caller id
Either COPY the config settings from a set where it works to those that don't, or on the sets that do not:
F**CONFIG, Terminals&Sets, (enter ext #), ... Telco Features, 1st Display Name: change between Name, Number, or Line.
And remember that some callers (esp Cellphones) do not provide Name info, so if the incoming calls at that extension are mostly from the same #s, it might be normal.
Aug 11, 2014 | NorStar Meridian M7310 Phone
Nortel Norstar M7208 always reads "Calls For You". What can i do to clear display?
This is Caller ID log
FEATURE 812 View Call Log
FEATURE 813 Manual Call Log
FEATURE 815 Deletes Call Log Items
To have no log see your office administrator or call your local tech to De-program your phone from the system log.
Nov 28, 2012 | NorStar M7208 Corded Phone
All 3 phone sets have no dial tone and arrows to each of the 8 lines are flashing. The caller ID window is blank - no info. The telephone line is working as I am receiving faxes - help?
This usually means the PBX unit is booting up.
Try power cycling the PBX unit. If that does not work, there is some hardware failure on the PBX.
Feb 28, 2011 | Nortel Meridian M7208 Corded Phone
Do the Norstar M7208 and Aastra 9120 phones compatible on the same PBX? I have a M7208 that works fine on current PBX, but new Aastra 9120 doesn't work. Should they both operate on the same PBX?
Dec 23, 2009 | NorStar M7208 Corded Phone
How do you set up caller ID on a Norstar M7208 phone with 4 lines?
Jul 23, 2009 | NorStar M7208 Corded Phone
Nortel M7310 Display Caller
In system programming your station needs to set caller id to Y.
i am assuming the system accept caller id. Other stations are working.
Jun 22, 2009 | NorStar Meridian M7310 Phone
Carl
Jan 08, 2009 | NorStar M7310 Corded Phone
Caller id only displays after i pick up the line
it is a progrsamming issue that can be fixed where are yuou located?
you can call me at 3107016774
Sep 18, 2008 | NorStar Meridian M7310 Phone
Caller ID
First off seven to nine you do not use an external cid unit for norstar systems. Make sure you have a caller id card in the main ksu or key service unit( the phone cabinet) It should say CI on it. If the card says DS then you do not have a caller id card on the system and will need to exchange it for one. Then the system phones will have to be programmed for cid.
Feb 16, 2008 | NorStar Meridian M7310 Phone
Nortel Meridian M7208 Corded Phone Logo
29 people viewed this question
Top Nortel Lands Phones Experts
Sanjaya Sahu
Sanjaya Sahu
deton8 von Splosion
Are you a Nortel Lands Phone Expert? Answer questions, earn points and help others
