Please advise what kind of phone system you are using. Can you dial in from outside and answer? This tests basic connectivity. Is there an old style analog phone and jack where you can bypass the system and test?
Try dialing with all digits and just local dialing (could be just 7) - any difference? My gut feel is that your provider changed to mandatory all digits dialing, even if local call.
SOURCE: fax machine error
I called Kodak support and had to upgrade firm software and reset all the settings to reflect whether I had an answering machine (yes) and call waiting (no). Also found it helpful sometimes to dial out using commas after the 1, to keep it from ringing busy.
SOURCE: brother mfc-420-cn all faxes are always busy
Normal
0
Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off.
I'd do both and reinstall the CD software program that came with
the printer. When the software program asks you to connect the
printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
SOURCE: after dialing 4 numbers the phone goes to a busy signal
First Option:
Phone in the Other Sim and check the Phone Network Signal If Network Signal Problem not Solved So
Secend Option:
Your Phone Network IC Fault So Please change Network IC
And Network Signal Problem will Solved
if it is there isn't much you can do on this side of the network.
Contact your phone company.
