I have a Samsung DV501AGW Gas Dryer.
Also note, if you don't have enough clothing to make constant contact with the moisture sensors it will think the load is dry.
Your dryer has a moisture sensor that determines how long the drying cycle is on. When the dryer is first started it has an initial run time based on the selected setting. When the sensor starts measuring the moisture the drying time will change to a shorter run time if the items are not too wet. It could also be that the sensor needs to be cleaned. Dryer softener sheets can coat the sensor over time and prevent the sensor from accurately reading the moisture. You can use s scrub pad such as a scotch-brite to gently clean the sensor. https://www.samsung.com/us/support/owners/product/gas-dryer-with-steam-dv501ag
SOURCE: whirlpool awm 9000 auto front loader washing
FH means there is No Water or that's what it thinks.
You either have a water problem or a faulty water valve.
Hope this helps
SOURCE: I have a GE front load dryer, model DBVH512EF0WW.
Try unplugging from wall for while and then see if this resets it.
SOURCE: My dryer timer counts down to 7 minutes and then continues drying
replace the sensa board and make sure the wires on the sensors are ok
SOURCE: Kenmore Elite Gas Dryer: Dryer does not dry
SOURCE: Timer counts down very fast
The keypad control board will need to be replaced, bare in mind the cost for the part will exceed the price of a new microwave oven in some cases.
