Ref does cool. A short while after compressor comes on there is a clicking sound from the ref.
SOURCE: Side by side stopped working but clicling noises every second two.
Ok the motherboard is malfunctioning. Ive observed this exact problem before. Replace the board and all will be normal again. If you keep lettig it click and click it may finally kill that relay that you descibed to me or even worse the compressor itself.
SOURCE: Kenmore frig will not cool
if compressor is hot that means comp- is trying to start but the relay /overload is bad allow comp to cool down unplug from wall and replace with exact type 1/2hp 1/4hp 1/3hp etc make sure all wireing is correct and unplug before starting that model may or may not have a run or start capacitor replace it also..
SOURCE: Sears Kenmore 53652300, doesn't cool
This usually indicates that the compressor is working too hard and drawing too much current. The click that you hear is a safety shut-off. Possible causes of this are numerous and usually require having a professional come in to fix the issue, it can range anywhere from a faulty compressor to a bad start relay.
There is in most cases a temporary fix, it is called a hard start relay/capacitor. It is usually available from an appliance parts retailer for around $15 to $20. Installation instructions are included, just be sure to unplug your refrigerator first and make sure that someone following you can repair from where you left off. This relay assembly can normally get you up and running but it should not be used as a permanent fix. This will not correct for a refrigerant leak in the system.
Check your refrigerator owners manual before making any repairs or modifications to your refrigerator, there may be an extended warranty on the sealed system and compressor.
SOURCE: GE bottom freezer began making a clicking noise, will not run
The clicking could be the start relay.If the start relay is bad, the compressor will not start and you will hear a clicking noise in 2-5 minute intervals. The clicking noise is the overload cutting the compressor off when it overheats from trying to start with a bad start relay. To find out if this is bad first unplug the refrigerator. Remove the lower cover from your refrigerator. Then take the cover off that is on the side of the compressor,you will see wires going to this. Now you should be able to see the start relay plugged on to the side of the compressor and unplug it. Now the best way to tell if it’s bad is to shake it. If it rattles, it’s bad and needs to be replaced. If not, most of the time it’s ok. But rather than saying the compressors bad, you might want to replace it anyways because it don’t cost much in most cases (less than $25). If you replace it and it doesn’t work then the compressor is bad and you’ll need you call a repairman. (Note that compressors are very costly and are normally not worth fixing). You can also enter your model # at www.appliancehelponline.com for diagrams and illustrations.
SOURCE: g.e refrig gsh25jre makes a clicking noise refrig
The clicking noise means the computer board is bad. It will have to be replaced.
The freezer control will normally make a ticking noise when starting and stopping the compressor. If it is clicking on and off in abnormally short intervals, you could have a component failure that needs a technician's attention.
The overload on the compressor will also make a clicking noise when it trips. If this overload is tripping, the refrigerator and freezer will normally not be cooling properly. This lack of cooling may take several days to appear.
