SOURCE: how to reset the meter of lamp
You need to have your Panasonic remote.
1. Make sure the power cord is plugged into a properly grounded outlet and turn on the set with the power button on the projection unit or the remote control.
2. While holding down the (VOL -) key on the projection unit press the PIP or SPLIT key at the same time. Hold it for longer than 5 Seconds. The PIP or SPLIT key is model specific:
PIP for Models:
PT-50LC13/PT-60LC13/PT-50LCX63/
PT-60LCX63/PT-43LCX64/
PT-50LCX64/PT-60LCX64
SPLIT for Models:
PT-43LC14/PT-50LC14/PT-60LC14
3. When the unit resets the lamp timer it will display a screen on the TV indicating it was reset to zero. You press recall on the remote to exit.
You will find a PDF of the instructions at this site:
http://fixyourdlp.com/blog/wp-content/uploads/2007/09/panasonic-tyla1000-lamp-instructions.pdf
SOURCE: no picture new lamp
try turning the projector on and wait for one minute. On the projector keypad, press and hold the Volume + and Volume - keys for ten seconds.
SOURCE: I have a KF42WE610 Sony TV, lamp was changed 8
Lamp Fan. or Ballast Board. for part number and prices call Encompass Parts 1-800-638-3328
SOURCE: PLV-Z5 projector lamp won't light
Hello
The answer is NO. Anyway you have to access its menu before and after the replacement of lamp.
There is Note in the lamp replacing procedure, that "Do not Reset Lamp Replace Counter when Projection Lamp is Not Replaced.
If you can access the menu button, inform me Through Fixya. I will send you the rest of proceedings to set its counter. If you can't access the menu, there is no other way than contact the authorised Sanyo service center. Ok.
