Question about Hotpoint Ariston AWD129 Front Load All-in-One Washer / Dryer
HI AND THANKS FOR YOUR HELP I HAVE ARISTON AWD129 AND I NEED DOR HANDLE AND WATER FILTER IT IS POSSIBLE TO BUY ON CHULA VISTA AREA THANKS
    Top Expert:
  • Hotpoint Master
  • 61,937 Answers
FIXYA HAS NO IDEA WHERE YOU MIGHT FIND WHAT YOU WANT SORRY
Posted on Mar 06, 2019
4 Suggested Answers
SOURCE:
SOURCE: have a problem with my panasonic
ERROR F61
Posted on Feb 18, 2009
  • 1417 Answers
SOURCE: Hi and thank you for you possible help. After
hello,
what this indicate is that there is a blockage on the water lay(pipe or drainage ) water out flow.
what you need to do to fix up this problem from first of all put off all form of power supply connected to the washer then bale out the water from the drum and them trace the pipe(hose) that is the way out for water you will see or fine some dry that has block the drainage remove all dirt as the case may be then the problem is solve once you can remove the dirt that has block the drainage
around the pipe blockage then problem of the drainage will be solve .
thank you and thank for using fixya.
Posted on Aug 28, 2010
  • 3154 Answers
SOURCE: I'm trying to find a very old song that my dad used to sing that in part goes: Ba Dum Pa Dum Chula Vista Chula Vista and that part repeats a couple of times any help would be appreciated
Just shooting in the dark, but is this what you mean?
Chula Vista song
Posted on Jun 17, 2015
First, the machine started to do a strange noise during the cycle. At the end of the cycle, I couldn't open the door because there were too much water in the machine, so it means that the cycle...
Check for a blockage. Or try to buy a washing machine cleaner and put it inside without clothes and run the machine alone. This will help. If it won't then you will need to get a new machine
Nov 11, 2012 | Hotpoint Ariston AWD129 Front Load...
Can not drain water/dry clothes
Hi Mark from retired Englishman in SW France,
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Following are my complete and hopefully 'coverall' pre-typed guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Sep 14, 2011 | Hotpoint Ariston AWD129 Front Load...
Hi,I got an Ariston Margherita 2000.It does work well,but the end of the cicle the water doesn`t dissapear from drum.I tried everything,but nothing happend. Many thanks. Zsolt
Hi Zsolt!
The problem can have more causes:
1. At the lower part of the machine is a kind of filter for the dirty water. It is possible it need to be cleaned, a lot of stuff can be stucked there. To get to the filter you have to remove the pannel from the front lower part.
2. The used water pump itself can be the problem, then it need to be replaced.
3. The command unit doesn't work properly so the pump for draining the used water does'n start.
It is quite simple to determine if this pump is starting or not, because it makes during running a tipical sound.
Hope it helped.
Regards,
Bogdan
Aug 21, 2011 | Ariston Technologies Washing Machines
I cant start washing machine as red light buttons are stuck
Possible that the program controller unit is faulty and so there is need to check the voltage on the controller to confirrm the fault.
Mar 18, 2011 | Hotpoint Ariston AWD129 Front Load...
Elna serger 925 presser foot lift lever broke off.
Here are 2 dillers that will repair it for you.
Sew Pros Inc 393 Broadway
El Cajon, CA 92021 (619) 442-3100 4.61 mi Burdick's Chula Vista Sew 278 Third Ave
Chula Vista, CA 91910 (619) 422-5325 10.56 mi
Good luck and please rate
Sep 16, 2009 | Elna Sewing Machines
Rinse cycle
If the machine has a soak cycle, you can use that. If it does not, you can have it fill on a cold rinse, and then stop it for a soak. Restart it on a hot wash with a cold rinse. Tumble dry low.
May 14, 2009 | Ariston Technologies AWD 129 NA Washer/...
Door Stuck after wash completed
You will have remove top cover, and release door latch from inside the front, with a screw driver pushing against the latch to open door.
It does mean that you probably have a faulty door lock, or broken door handle.
Please rate my fixya solution.
Thanks
Jan 11, 2009 | Ariston Technologies Ariston AWD12 Front...
Hotpoint Ariston AWD129 Front Load All-in-One Washer / Dryer Logo
24 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
James Hehling
James Hehling
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
