SOURCE: loss of internet connection
Sounds like a switch before the signal gets to your house. Modems usually don't go out intermittently unless they are overheating. Is the modem in a ventilated area where it can get some air? An alternate is to borrow a modem from a friend to test it. Usually one of your niehbors will have the same service and the same modem. I had my surfboard (from comcast) for 5 years and it was solid as a rock, the spotty services was always at the Comcast switches (at the street or the nearest hub.
Hope this helps
SOURCE: Tesltra 2-wire modem question
http://forums.whirlpool.net.au/forum-replies-archive.cfm/808533.html
Some explanation here guys :)
SOURCE: LG Shine CU720 -cannot access the internet or mms-unlocked phone from Telstra
I have an Lg Shine CU720 and I can't unlock it. Can you help me please. I need an unlock code.
SOURCE: ATT has given me a 2 Wire Gateway... which does not work
Try to reset the modem from the bottom of it.. press and hold it down for 15 seconds.. check the status of the lights on the power... try to do that and lemme know.. if not you might have to get in touch with the att tech support.
was i help ful?
SOURCE: att modem has been working fine, but sudedenly
Did u change the password for your email address ( username ) for the AT&T email
This should be the only reason why the internet light is red
Please update the password on the modem
