Question about Pride Health & Beauty
How to remove the real wheel on a pride victory 10
    Top Expert:
  • Pride Master
  • 62,042 Answers
A REAL WHEEL ???
Posted on Mar 06, 2019
  • Rita zDaniels
    Rita zDaniels Mar 06, 2019
    Posted in the wrong place obviously.
SOURCE:
  • 118 Answers
SOURCE: Pride victory mobility scooter
1. Remove the four screws on the outside perimeter of the console base.
2. Lift off console top cover and disconnect the front-to-back cable.
3. Remove the throttle lever from the throttle pot.
Remove the four screws holding the console base to the mounting plate.
Posted on Nov 27, 2008
  • 175 Answers
SOURCE: THE SCOOTER MAKES A HIGH PITCH NOISE WHEN THE KEY IS TURNED ON
The buzzer is a piezo-electric device that is the "horn" for the scooter. It also will alert when the scooter is in reverse, if this option is programmed into the scooter. It receives its power from the PC board or console board which is located inside the top of the shroud at the tiller, where the thumb paddles that direct the scooter are located. If liquids have reached the board, or if condensation has affected the board, the circuit that controls the buzzer may have shorted causing it to come on constantly.
Opening the top of the shroud is fairly simple. Remove about 6 screws holding the clamshell cover together, remove the speed adjust knob, and it should come apart. Inside you'll see a PC (printed circuit) board, green in color with lots of small electronic parts embedded on it. The buzzer is also inside, usually about the size of a marshmallow and black in color with tiny holes to let the noise escape. There will be two wires leading from the buzzer to the plug-in at the PC board. Unplug the buzzer and the noise will stop, but you won't have use of the "horn" at all. Replacing the PC board can be done by a certified Pride tech, but it will probably cost you about $150.00 for parts and labor.
Hope this helps.
Posted on Jul 07, 2009
  • 175 Answers
SOURCE: Having trouble with a 3-wheel Pride Mobility
Check that it is unplugged from the charger. Then check the freewheel lever to ensure it is in gear by placing it out of gear first, then placing it firmly in gear. Do this while the key is OFF. Wait three seconds, then turn back on and it should go.
If it doesn't, and you are sure it's in gear and unplugged from the charger, you should be getting a fault code flashing on the charger display. Consult your owners manual to determine the fault and proceed as recommended.
Here's a link to the owners manual if you've lost yours. Good luck.
http://www.pridemobility.com/pdf/Owners_Manuals/US_Scooter/US_Victory_om.pdf
Posted on Jul 11, 2009
uxair shah
  • 812 Answers
SOURCE: I have no manual for my Pride Victory 4 wheel
Hello i hope u 'll be fine.... thanks for using fixya.
You can easily get the manual for Pride Victory 4
Download it and Enjoy
You can also see lots of effective information of your product from this.
  • Manual is in pdf format if you have no Adobe Reader software which support pdf files then Download it from here Adobe Reader
I hope this solution will helpful 4 u. Best of luck
Please do rate if it is helpful
THANKS
Posted on Mar 02, 2010
  • 61 Answers
SOURCE: pride victory 10 clicks while going foward
If the click is coming from one side of the rear of the scooter, I would think you have a dry axle. If this is the case, you will hear a regular clicking noise, just as if there is a stone in the tyre. All you have to do is remove the wheel, apply some grease to the axle and re-fit the wheel again. When removing the wheel, be careful not to loose the hub key (usually a small strip of square metal that fits in a groove in the axle and wheel). This clicking noise is a very common problem with Pride scooters and one we regularly deal with, even on brand new scooters. If this doesnt cure your problem there are a number of other things it could be, but i would need more specific details to try and help you. Hopefully its just the axle! Hope I have been of some help to you.
Posted on Mar 23, 2010
What does the 7 beep code mean on my Pride Victory 10 scooter mean when I turn the key on ?
This is a speed pot or throttle control problem (wig-wag) have you had some speed issues with the scooter before this happened, if so the wig-wag needs replacing. Make sure it is in the centre position at rest and switch the scooter on again.
Jul 11, 2014 | Pride Mobility Products Pride Victory 10 -...
What does the 7 beep code mean on my Victory Pride 10 mean when I turn the key on ?
Hi , 7 bleeps is the throttle pot error , either a calibration problem or a faulty pot, i can help you , please contact me
Regards
Rob
www.gewizrepairs.co.uk
Jul 11, 2014 | Pride Victory 4 Wheel Mid-Size Electric...
Pride mobility victory XL front tyre wear
Is your track rod bent or out of alignment? Carefully buy the exact wheels with tyres and a track rod if necessary from dismantled Victory XL scooters (a good wheel with a good tyre about €30 - I've done that for my Pride Celebrity XL8 - it was a great success.
Jun 03, 2014 | Pride New Mobility Victory XL 4 Wheel...
My pride mobility victory scooter will not charge
You must charge each battery individually with an automotive NON automatic style battery charger until each battery has at least 10 bolts each. The scooter charger cannot pull up a battery with less than 10 volts.
Jan 14, 2014 | Pride New Mobility Victory XL 4 Wheel...
Battery charger not working. A white wire that connects to the AC plug has become disconnected. Can soldering it back on work okay?
yes this is a common problem on a victory scooter i know i have one and the same problem just solder it up carefully
May 02, 2010 | Pride Mobility Products Pride Victory 10 -...
Pride victory 10 clicks while going foward
Mar 22, 2010 | Pride Mobility Products Pride Victory 10 -...
Health & Beauty Logo
51 people viewed this question
Top Pride Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
