SOURCE: Sharp AR-207
sounds to me that the power supply has blown, or fuse onthe power supply. If you remove the left side cover you will see the power supply. Please unplug the machine first. check fuses if they are good, the power supply is bad.Let me know if you need more help.
SOURCE: TV doesn't turn on. All power sources working.
Check the main power cord for proper fit from the wall too the tv. Make sure the cord is well fitted in the outlet and the tv. If the connection is in standing and there's ac voltage coming from the outlet.......then it
may be a blown fuse or a dead power supply circuit with-in the tv. If so, the tv needs to be serviced.
SOURCE: HP LaserJetIIIP - just won't switch on - cable and fuse OK
I can't believe that someone is still using one of the first LaserJet printers I got certified on!!! If you really want to gut the machine, there is a fuse in the power supply that could have blown. It is also possible that the power supply has finally died on its own after all of these years. You may just want to check the output voltages first to make sure of the status. If some voltages are present and not others, the fuse is still good, but the output circuitry is shot, in which case you would need to get a replacement power supply (if they are even available anymore).
Be careful with the disassembly process. The plastic clips may be brittle after almost 2 decades and could easily snap apart.
SOURCE: does it have a inline fuse or relay and where is
if you bang on the tank and it runs fine for sum time ! the fuel pump is on its way out !the brushes in the pump are worn !replace pump ! and relay ! relay is under the hood on drivers side
