Garden Logo
P
Phil Jones Posted on Mar 06, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Pope brush cutter 101PBC33 not going to full revs. Have checked air filter, muffler and fitted new carb. ran it without muffler still the same
roeb
Level 3:
  • Garden Master 819 Answers
  • Posted on Mar 07, 2019
roeb
Garden Master
Level 3:
Answers
819
Questions
0
Helped
384706
Points
2343
Make sure throttle cable is opening carb. Fuel butterfly valve completely. The cable may have slipped in tube.
5 Related Answers
Anonymous
  • 23 Answers
  • Posted on Mar 25, 2009
SOURCE: GSXR 750 Slingshot wont rev past 5000rpm, with or without choke
I have seen this before a few things to do too make sure. First take the air filter out and shine a light use your fingers to move the slides up and down I suspect the springs that go on the slide is not seated in center you can tell from the slide going halfway and hanging up. Next, the boots on the slides only go on 1 way there is a notch on the carbs for them. I would guess this would fix you up if not we can get deeper into it with air-fuel mix screw settings.good luck
Anonymous
  • 87 Answers
  • Posted on Apr 10, 2009
SOURCE: echo blower motor will not rev.full throttle--only about half
Check the insulator block and associated gaskets behind the carb. Sometimes the insulator block crack and reduce the amount of vacuum to the pulse diaphragm.
Anonymous
  • Posted on May 25, 2009
SOURCE: low rpm's from Echo PB-251 leaf blower
Too much oil in gas.
Anonymous
  • 242 Answers
  • Posted on Dec 23, 2009
SOURCE: Will not reach full rev and power.
check carb and clean jets
rycgl
Roy Cagle
  • 1545 Answers
  • Posted on Nov 09, 2010
SOURCE: Hi, I have a ryobi BC30 brush cutter my fuel lines
The small diameter line out of fuel tank (has filter in-tank on end) connects directly to the side of the carburetor that has the fuel pump....that is the cover without the hole in it. Other larger diameter fuel line out of tank connects to the longer nipple on the external purge/primer bulb. The bulb "pulls" fresh fuel from the fuel tank to the carb and then out of the carb to itself, where it then "pushes" any air/old fuel back into the fuel tank. The remaining larger diameter fuel line in this setup goes from the metering chamber (has cover with writing on it and a vent-hole) side of the carburetor to the smaller nipple on the purge/primer bulb. Again, on the primer bulb, the longer nipple has a line going directly from it to the tank. This is the return line. The shorter nipple on the bub has a line from it going to the metering chamber side of the carb. If the purge/primer bulb is on top of the carb...small line from carb body to small hole in tank with filter. Larger diameter line goes from the bulb on the fuel pump side of the carb to the larger hole in the fuel tank where sometimes the line is held in place with a nylon nipple connector that keeps the line from pulling out of the tank. Otherwise, the line should enter the tank for about 1/2" or so
Hi my suzuki gz 125 wont idle correctly and when i rev the engine it just dies down and cuts out i cant even achieve a stable idle speed
I had this problem today with my bike and after much ado I discovered there was oil in the air filter box... check your oil level it could be too full. Mines was and the excess oil was blown into the air filter box and as a result contaminated the air filter. Spent today cleaning the filter box, carb and draining and changing oil, could not get a new air filter today so ran it without onebike runs like new!! New air filter will be here Monday!
1helpful
Carb full of gas
sounds like the float is sticking inside the carberator might need new needle and seat as wel as a float check to see if float is gas logged
How do i adjust the fuel air mix on a 2012 cub cadet bc210 trimmer
there is a special tool that fits the splines on the carb screws, part no. 530035560, before adjusting the Hjet make sure the air filter is clean, and if it has a spark arrestor in the muffler outlet check it has not carboned up, both of these things will cause the engine to run rich.
May 19, 2012 • Garden
1helpful
Installed new carb-saw will idle fine,but will not rev.Idle scew has no effect on r.p.m.As soon as you hit the throttle,saw dies.Almost act's like the chain brake is on but it is dissengaged.Both...
There are a few things to check, if the muffler has a spark arrester gauze in the out let this may well be blocked, remove the muffler and the gauze, does the engine now rev? if yes either the park arrester is blocked or the muffler itself is blocked, if this does not cure it, check the flow of fuel from the tank to the new carb, replace the filter in the fuel tank and try again, if this does not help try running the saw with the air filter removed, if it revs normally the filter is blocked.
My Ryobi Brush Cutter will not run properly, It starts ok but I cannot get it to full power, it sounds like it is flooding almost. I have replaced the sparkplug, emptied the fuel tank and put in new fuel,...
There may be dirt blocking the fuel supply to the engine. You need to strip and clean the carb, preferably fitting a new carb kit at the same time. Clean out all the passages and orifices by blowing them out, but be careful of loosing small parts like filter screens and screws.
Jul 11, 2011 • Garden
It is very hard to start, uses a lot of fuel and stalls all the time. It seems almost as if the carb is stuck on full choke all the time.
Check the esay things first, clean the air filter ( just try it without the filter on as a test free running ) check if fitted the spark arrestor in the muffler outlet.
Jun 27, 2011 • Garden
1helpful
Just bought a 1993 suzuki gsxr 750. has been sitting in a garage for 2 years. we took the carbs off and cleaned them really well, changed the oil, and air filter and we added new gas. bike starts up and...
If is runs better with full choke, then the bike is lean, check for air leaks at the carb manifold, vacumn cracked hoses, non standard exhausts, perhaps the mufflers have rusted out while sitting
3helpful
2answers
I have a Ryobi brushcutter that is 4 years old.When I was using it the other day it just would not run at full throttle. I checked spark plug,air filter and fuel filter. No adjustments on carb. I have no...
Smokey 2 cycle oil will cause the exhaust ports to carbon up and plug the spark arrestor.
Remove the muffler, use a pick to clean out the exhaust port on the engine, and the muffler inside opening, then clean the spark arrestor screen, to assure yourself you are correcting the problem start the machine up with the muffler off, it should run like a charm, if it goes back to running badly when you reattach the muffler it may be clogged on the inside.
I’m happy to assist further over the phone at https://www.6ya.com/expert/gregg_78ecbb34e27be215
3helpful
2answers
Top Garden Experts
Jay Finke
Jay Finke
john h
