SOURCE: Loose handles - GE monogram model # ZFSB25DMD SS
try removing the handle, that will expose the mounts for the handle. You should be able to tighten them after removing the handle.
SOURCE: leaking single lever kitchen tap
on most of the single handle faucets there is an erasure like button ( may have a hot and cold blue and red indicator or be silver ) usually located right under the faucet arm on the manifold chrome sleeve or back behind the arm or it could have a large ring nut over the doam of the lever take your hand and feel the area that covers the area where the spout arm swivels and feel for the button or take your fingers and fel the to of the lever doam
if you find the button just take a sharp screw driver( be sure to plug the drain holes and turn hot and cold water off under sink) pry the button off and use a hex wrench and loosten
if no button then there has to be a large nut on top you may seee two grooves oppsoite each other wheich would mean a special tool
use an adjustable wrench (put cloth ofer chrome to protect and turn counter clock wise( the ring nut will not be very thick
after removing you should be able to replace the cartridge
good luck
SOURCE: Amana AFI2538AEW bottom freezer door handle is loose?
My dad's freezer handle is loose, model ABB2224DEW. Went to partselect.com and located drawing of freezer door parts. Found a link to a "do-it-yourselfer" that describes removal and replacement of the handle. Hopefully this helps.
Replacement of freezer door handle.
1. Removed freezer door handle. First I read the freezer door handle removal instructions in the Amana refrigerator user guide. Removing the handle requires inserting a plastic card at least 1.5 inches under the left end of the right side of the handle so it releases the butterfly clip latch on the freezer door. Next I pulled the right side of the handle to lift it away from the freezer door. Then still holding the handle away from the door, at the spot that is 1.5 inches from the inside of the right side of the handle, I held the plastic card vertically and slid one corner of it between the handle and the freezer door and worked the card down until it released the butterfly clip latch. Keeping the card at the same space under the handle so the latch was released, I then turned the card to the left until it was horizontal and was lifting the left end of the right door handle away from the freezer door. I then slid the handle across the card to the left until it cleared both door butterfly clip latches and it lifted off the door.
2. Installed freezer door handle. First I read the freezer door handle installation instructions in the Amana refrigerator user guide. The handle is curved on one edge and must be installed the curved side down. Correctly installed, the outside ends of the handle curve upward and the handle curve is down so it looks like a frowning mouth. Next holding the handle curved edge down, I turned it up so I could see the brackets and held it against the door. I lined up the handle brackets slightly to the left of the butterfly clips on the freezer door. Next I turned the handle with the brackets against the freezer door and slid it slightly to the right until the left side of the handle held onto the door butterfly clip by itself but was not latched. Then I lined up the right handle bracket with the right freezer door butterfly clip and carefully slid the whole handle to the right until I heard the left butterfly clip latch click. Next I slid the handle back slightly left once more and then slid it back to the right until I heard the right butterfly clip latch click.
Parts Used:
HANDLE, DOOR (WHT)
Level of difficulty:
Difficult
Time to do repair:
30 - 60 mins
SOURCE: Handlebars loose
Construct shims from aluminum (soda / cola) cans with scissors. Be careful not to cut yourself, sheared aluminum is very sharp. After you have cut a wide strip of aluminum, wrap it around the handlebar and put it between the handlebar and the clamps. This will increase the diameter of the handlebar and allow your clips to exert more pressure on the handlebars making them tighter. Try not to leave any aluminum exposed after fixing it; it's sharp.
SOURCE: Door Handle Loose and tightening with allen wrench does NOT work ...
Just did this on mine today. Use an allen wrench to back off both the upper and lower set screws (Note: you do not need to back them all the way out). The handle will then easily pull away from the door. With a 1/4" socket, tighten the screws holding the upper and lower lugs on the door. Place the handle back on and tighten the upper and lower set screws.
