Everyone’s eyes see different colors. So there isn’t one setting that is perfect. There are also factors such as is what you are viewing is it a movie that was done on film or is it a movie that was say an animation? Some film stock will have different looks you will have to see kelvin color white levels too if you really want to add to the research. Some films have a yellow hue others are more blue. If it was filmed digitally then it could look better at either depending on the white balance. Bottom line use up the movie go through some settings and then most people just set it and forget it as it will change per movie or tv station.
SOURCE: BEST PICTURE SETTINGS FOR SAMSUNG 5044
Try this.... First, go into picture menu and reset it. Next turn contrast all the way up. Turn the sharpness all the way down. Make sure the tint is in the middle. Adjust brightnesses accordingly. If that don't work, just drop me a line and i will explain more
Best regards
CircuitCity
SOURCE: Connect LG 42LY95 LCD to Toshiba Laptop
Hiran
can you use the vga source from your laptop to the pc input on the LG a standard vga monitor cable will do then set your laptop to output the vga signal
Scott
SOURCE: samsung tv settings
Freeview Built-in Tuner
Picture Mode: Standard
Contrast: 85
Brightness: 53
Sharpness: 25
Colour: 45
Tint: 50/50 (Greyed Out)
Colour Tone: Cool1
Detailed Settings:
Black Adjust: High
Dynamic Contrast: Off
Gamma: 0
Edge Enhancement: On
White Balance:
R-Offset: 17
G-Offset: 15
B-Offset: 11
R-Gain: 7
G-Gain: 14
B-Gain: 30
Backlight: 10
Digital NR (Noise Reduction): Auto
Active Colour: Off (Greyed Out)
DNIe: On
Movie Plus: On
Sound Mode: Music
SRS TX XT: On
Game Mode: Off
Energy Saving: Off
SOURCE: Best Picture Quality
Check this link out. I think it should give you all the info you need for optimal picture settings.
http://help.cnet.com/samsung_LN_T4061/9602-12576_39-0.html?messageID=2510125&tag=tip-2510125&kw=samsung+LN-T4061
SOURCE: Thomson Scenium 52''Rear Projection TV set -
you have a laser that has gone out blue or green take the face off and see which of the colors you need you can still find lasers on ebay if you need one but it will require someone with a little expertise to replace them. if this is not for you then its time for a new TV this is probably the best option its more expensive to fix in most cases than to replace..........I hope this helps
