Question about Frigidaire Refrigerators
We have a fridgeidaire gallery model FGHB2844LF7 and the inside is colder then the outside of the door is set at. We have been having water lines inside the fridge, freeze because of this. Any help?
    Top Expert:
  • Frigidaire Master
  • 6,289 Answers
Damper could be stuck open allowing too much cold air into fridge section, or thermostat could be going bad.
Posted on Mar 05, 2019
  • 2 more comments
  • Brady Anderson
    Brady Anderson Mar 05, 2019
    Do you know where the damper is located on this unit?
  • Brady Anderson
    Thanks for the help by the way!
  • Chris Huff
    Chris Huff Mar 05, 2019
    It allows air to flow from freezer to fridge.
  • Chris Huff
    It is on wall that separates fridge and freezer
SOURCE:
French door water is too warm
Good Afternoon friend, thanks for your post!
With a French door refrigerator the water will come directly from your tap. If you would like to have the water colder you may need to run your faucet to allow the water to become colder before getting from your water dispenser. I hope this information is helpful. -Matt
Sep 30, 2014 | Frigidaire Gallery 25.8 Cu. Ft. French...
On my frigidaire gallery series oven, how do you clean the glass of the oven door window (between the inside and outside)?
Below are instructions on how to take your oven door apart to remove any stains that may be caught down in the door vents.
Tools needed: good Phillips head screwdriver or small quad bit driver.
A. Open Door remove 2 screws and washers on door lining at door hinge area.
B. With door in broil stop position lift door assembly off hinges.
C. Lay door on table, position so that handle hangs freely over edge of table
D. Remove 2 screws and washers that secure handle to lining assembly.
E. Remove 8 screws that attach textured steel door wrapper trim to lining assembly 3 at top, 3 at bottom, 1 on each side
F. Lift door lining up and out of wrapper trim assembly.
G. Lay lining assembly on table with wool shield/inner part of lining facing up.
H. Remove 2 glass clamps via 2 screws per clamp. These clamps attach innermost clear glass to wool shield.
I. Lift out center clear glass from wool shield, this glass just lays onto the wool shield and is held in place by the glass/ clamps in item H.
J. Clean each glass with appropriate cleaner, Windex, bon ami, fantastic, etc
K. One glass that remains in door lining assembly can at this time be cleaned without further disassembly the lining assembly.
L. Reassemble in reverse order.
Aug 16, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
Water not coming from gss25lgmb bb
I have a GSH25JSRFSS GE refrigerator. Twice, the water line has frozen near the dispenser. Each time I used a hairdryer to heat either the side of the door where the water line runs and blew hot air up the dispenser. This last time, I took the plastic cover off the outside of the door (it clips on) and blew hot air into the small holes in the door that the outside grate clips into. This allows the hot air to get inside the door, and I heard ice from the frozen line drop. Subsequently, the water line worked. Two points: I did have water running to the line in the bottom of the refrigerator, so I knew it was an ice clog, and secondly, I took care not to blow hot air on the exposed wires inside the door.GKAZ
Oct 23, 2011 | GE GSH25JSRSS Stainless Steel Side by Side...
Kitchen Aid Unit - maybe 4-5 years old but past warranty. Freezer not freezing. Not that cold in fridge. I played with the dials 1. Are higher or lower numbers on the knob coldest? 2. What else should I...
Set dial to higher number in the fresh food compartment (large door) set the freezer
knob on the vent stack in the center or to the left (if it is set to colder, this prevents cold
air from getting into the lower fresh food compartment). Colder means the freezer
gets colder.
Also if you have a failed defrost termination thermostat it will cause this
symptom on many models. (a lot of folks will disagree but I have only seen a couple
of defrost timers fail in 10 years). The water makes its way into the defrost termination
thermostat and corrodes the contacts inside. It is behind the freezer panel and has two
wires going to it. It is clipped onto a tube. You will need the model and serial from inside
the fresh food door (on the side panel) to get a new one, usually less than 20 dollars.
Remember to set the fresh food compartment temp from 34 to 39 degrees with a
thermometer in a cup of water for 24 hours. Don't forget to unplug unit if service is
required on the thermostat. Hope this helps.
Jun 08, 2011 | KitchenAid Refrigerators
I purchased a frigidare gallery french door with water and ice in the door. Model # FGHB2844LF . The water is no colder than the tap water, about 66 degree. We have the refrigerator set at 34 degree. Why...
Should be water storage behind the crisper drawer, you should be able to see it if you pull the drawer all the way out.
This refrigerator was not very well thought of when it was new. it only got 2.5 stars on the AJ Madison site.
Sep 26, 2017 | Frigidaire Gallery Series GLRT218WDZ 30"...
French door model installed yesterday with outside water & ice. the water is not cold from outside dispenser. have freezer set at 0 F and frig at 35 f
theres only so much water that resevoir inside can hold once it empties it must sit to cool or chill. once used then ur just gettin straight water from ur water line from the house...
Jan 28, 2010 | Electrolux Refrigerators
I have a refrigerator GE GSS25PGMF and I have no idea how I should get inside of the freezer door. I do not see any screws.
The doors are not made to get into . All parts are accessable from the outside , except , for the water line inside the door .
The liner and waterline , are set on the door , and then insulation material , is then piped into the door .
Oct 09, 2009 | GE Refrigerators
WAter dispenser stopped working
Change the filter in the refrigerator. ..just change it..
Is there something wrong with the kitchen faucet?..
drinking bottled water..??.. are you drinking ACID RAIN??.... think not...??
read this:
Acid Rain Students Site PH Scale
now read this..
Analyzing Comparing Brands of Bottled Water
Oct 11, 2017 | GE CleanSteel GSL25JFTBS
Refrigerator does not cool
If the refrigerator cooling is poor, it may be a problem with the thermostat, the compressor, or the evaporator fan. If ice is accumulating at the back of the fridge, that can also be a reason for poor cooling.
See aso the links below for a more detailed explanation:
It's not cool
Cooling is poor
Oct 04, 2008 | Kenmore Refrigerators
Refrigerators Logo
Top Frigidaire Refrigerators Experts
Steve Allison
Steve Allison
Thomas F. Schneider
Carmen Mikulic
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
