Question about Onkyo Audio Players & Recorders
Onkyo HT-R494. The bluetooth light on the reciever doesnt come on every time. I have to reset the reciever cbl/sat & power button then pair my phone again. It works for a few days then fails again.
SOURCE:
designyou
  • 13 Answers
SOURCE: Can't connecto to headset again...
You are not alone in this endeavor. A lot of people have this problem. So, here is what I suggest. 1. Make sure both the headset and the phone are fully charged. 2. Delete the "device" from your phone. I mean precisely that. Go into you cell phone's bluetooth settings and erase your "HS850" from it. 3. Try re-pairing it. Put the phone and the headset in pairing mode and allow it to sync. This should do it. I always works for me. You usually only need to pair once and every time you use the headset all you should have to do is connect it. I hope this works for you. Good Luck.
Posted on Aug 02, 2007
  • 298 Answers
SOURCE: Onkyo TX DS575x reciever remote problem
You might try this replacement
http://www.remotes.com/remotes/servlet/rs?a=gmi&uid=11953114154530&smodel=TXDS575&brand_pn=ONKYO_TXDS575
Posted on Nov 17, 2007
  • 32 Answers
SOURCE: headset does not flash red/blue so I can pair it with my phone
To get it into pairing mode (flashing red and blue) turn the headset off.  Hold the main button down until the light goes red and then off.  Then push and hold that same button and keep holding it even after the blue light comes on.  It will now go into pairing mode, flashing red and blue.  Set your cell phone to find it and it should work.
Posted on May 22, 2009
SOURCE: pairing s9 headphones w/krzr
OK I managed to get my head set to work. Make sure the unit is charged, press and hold both the 'ON' button (on neck piece) and the "PLAY/PAUSE' button on the right earpiece. Keep holding then the LED should flash Blue three times THEN flash alternate RED and BLUE. You should then be able to Pair the Device. Good luck
Posted on Jun 19, 2009
SOURCE: I have an Explorer 210 series. It will no longer pair
Just this morning I was able to pair this headset with my phone. Before, it was paired to my PS3. The key is to hold down the big round button on the outside until the light flashes red/blue (this is quick-pair mode) then just have your cellphone search for bluetooth devices and you're done!
Posted on Nov 05, 2009
Testimonial: "I tried that but I bet I didn't do it long enough. Thank you so much (I exchanged it already but will keep in mind). Thank you again!"
Audio problems with HT-S7100.Sound only comes through center speaker and subwoofer. Sound is very tinny. Zone is off and can't be turned on.
Hi Tori,
Not sure if this has been resolved for you. If it has not please email me the units serial number along with a copy of the dated sales receipt so that I can see what options I have for you. Please email me at askOnkyo@us.onkyo.com, Thanks, JT
May 10, 2015 | Onkyo home theater system HT-S7100 User...
TX-SR333 Bluetooth worked the 1st time now won't pair up.
Hi, Please try the following reset and then try to pair again.
To do the reset you need to turn the receiver on, then on the front panel of the receiver press and hold the "CBL/SAT" button while doing that press the "STANDBY/ON" button. You will see the word "Clear" in the display screen and the receiver will go into standby mode. PLEASE UNDERSTAND THAT YOU WILL LOSE ALL YOUR AUDIO & VIDEO ASSIGNMENTS ON THE RECEIVER PLUS YOU WILL LOSE ALL YOUR SPEAKER CONFIGURATIONS, SPEAKER DISTANCE AND ALL LEVEL CALIBRATION SETTINGS. YOU WILL ALSO LOSE ANY PROGRAMMED RADIO STATIONS IN MEMORY. Once the receiver goes into standby mode turn it back on and go thru the setup menu for all custom settings, Thanks, JT
Feb 27, 2015 | Onkyo TX-SR333 5.1-Channel Home Theater...
We have "HT R670" and "HT R360" A/V Receivers with questions regarding Universal Remotes and Android Apps.
The Onkyo App will not work with the HT-R670. This receiver is part of the HT-S6200 Home Theater package and is not network compatible. You might be able to use the Logitech Harmony Hub and app or another remote control app paired with an IR repeater pointing at the receiver. Some universal remotes may support changing the inputs on the receiver. However, I don't know of any specific model that will work. The Logitech Harmony remotes are probably the most likely to support the Input button; it may take programming a specific button to match the receiver's Input function. If you need a replacement for the original remote, one source is https://www.amazon.com/OEM-Onkyo-Remote-Control-HT-S6200/dp/B0137R62H2 . The manual for the HT-S6200 is available here: http://www.intl.onkyo.com/downloads/manuals/pdf/ht-s6200_manual_e.pdf .
I can't find an Onkyo HT-R360 listed even as part of home theater system. There is an Onkyo HT-RC360. The manual for that is http://redirect.onkyousa.com/redirect_service.cfm?type=own_manuals&file=SN29400649_HT-RC360_En_web.pdf . While this model has a network connection, it is not compatible with the Onkyo app either.
I wish that I had better news for you.
Nov 11, 2017 | Audio Players & Recorders
HDMI ports CB/SAT and Aux do not work on HT-R670
Check your setup menu and make sure that the cbl/sat and aux functions are set to look at the hdmi jack and not another type of input like analog, optical, etc.
Jan 03, 2013 | RCA Onkyo Ht-r670 7.1ch Receiver From The...
Hi, I am having trouble hooking up my new LG home theatre system with my Rogers cable. I connected the home theatre system to the TV with an HDMI cable. The sound works with watching DVDs on TV and...
To listen to Tv program sound through your home theater system you will have to connect a pair of RCA to RCA cables (Red and White pair ) from the audio out socket of the TV ( some times three sockets Yellow/Red/White labeled Monitor out. Ignore the yellow as it is video out ) to the Aux or CBL/Sat input of the LG system. Then to listen to the sound through your LG HT system switch the Input selector of the LG to Aux or CBL/SAT. Will work for sure.
Mar 08, 2011 | Audio Players & Recorders
How do u plug in a dvd player
the onkyo receiver should have hdmi jacks on it labeled cbl/sat,dvd, and so forth. plug the hdmi wire into the dvd and from the dvd to the hdmi jack on the onkyo that says dvd. then run another hdmi cable from the hdmi out jack on the onkyo receiver to the tv
Oct 21, 2009 | Onkyo HT-SR800 System
No surround sound from my PS3 through the Onkyo 5100. Video OK
Unfortunately only the higher end Onkyo Reciever pass audio over HDMI for sound. 605,705,805,905 exc. Your reciever will carry Video over HDMI but you will need a digital optical cable for sound.
thanks.
Jan 24, 2009 | Onkyo Audio Players & Recorders
Onkyo HT-SR800 won't turn on
If you call Onkyo directly, 201-785-2600, there is a procedure to "reset" the system, something like holding the power button on and holding down another button for a few seconds. Can't remember which, so I can't be sure, but try giving them a call.
Jan 02, 2009 | Onkyo HT-SR800 System
Onkyo HT-R501 7.1 reciever issues
i have the same problem with a onkyo tx ds494
Jan 05, 2008 | Onkyo TX-SR605 Receiver
42 people viewed this question
Top Onkyo Audio Players & Recorders Experts
Ted28
Level 1 Expert
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
