Question about Refrigerators
The ULN-15WCSS-00 stopped running (cooling). The light comes on.
    Top Expert:
  • Refrigerators Master
  • 63,373 Answers
Suspect it needs freon added and if not equipped with the fitting then only a pro can do it
Posted on Mar 07, 2019
5 Suggested Answers
SOURCE:
  • 3600 Answers
SOURCE: Wine cooler #ULN-75BWC-00 motor seems to have shut
the motor could be defective or it could be low o refrigerant causing the pressure switch to not kick on the fan. Could even be wires have come loose from the fan. If the fan does not work it won't cool. however it mould most likely cosy you more to fix if you take it to a shop to have it repaired if you have the tools to test it with I can help you so let me know if you have a test meter volt ohm meter and I can tell you how to test the system.
Posted on Feb 15, 2010
  • 176 Answers
SOURCE: my uline keeps running and soda in cans freeze.
your thermostat is bloked or didn't see the reeal temperature, it must be replaced whit similar new one.
Posted on Feb 21, 2010
jyackle5
  • 8197 Answers
SOURCE: How do I access and
To learn how to remove the thermostat go to the link below and order a service manual
http://www.u-line.com/customer/
Good Luck
Posted on Dec 05, 2010
  • 135 Answers
SOURCE: MY COLD CONTROL IS BAD
go to googlr type your refrigerator brand name and parts .
if you would not get. see me e-mail wongjimmysoon@qq.com
i need brand name and model #
Posted on Jan 11, 2011
I have a U-Line ULN B198B-00 and the water won't shut off. It ends up filling the ice bucket and overflowing. Could it be a bad solenoid??
If you can get to the solenoid you could remove the solenoid connector. If it shuts off then I would suspect the ice maker timer. if it doesn't shut off I would suspect the water valve/solenoid.
Aug 16, 2014 | U-Line ULNSS1095 Marine Series 12-lb...
My uline keeps running and soda in cans freeze. Thermostat setting is at lowest but I also tried midway. Model ULN-CO75FWH-00
Feb 21, 2010 | U-Line Uline Origins Series...
Wine cooler #ULN-75BWC-00 motor seems to have shut off and no longer cooling. Please advise possible issues & parts to be replaced. Unit about 7 yrs old.
Feb 15, 2010 | U-Line Wine Captain (2015WC) Wine Cooler
Ice maker will not harvest
As crazy as this sounds, turn the temp control a little warmer (counter clockwise). On this model, this control needs to switch to harvest the ice. A warmer setting should fix this issue.
Dean
You can also go to:
www.u-lineservice.com
Jun 05, 2009 | U-Line Refrigerator Ice Maker
NO POWER GETTING TO UNIT
realized that there was nothing wrong with the unit....It is suposed to drain out water when running and need to jump start it...so alls good thanks for getting back to us...now were chilling.E.Bates
Jul 07, 2008 | U-Line Icemaker
U-Line Model ULN-CLR60B-00
call 1-800-779-2547, U-Line's tech support.
Has to be a bad a switch, wiring issue or maybe a control board. pull the service cover and see if the red light is lit on the board (or flashing). Light on (no flashing) indicates the board is powered up and no errors are occurring.
http://www.u-lineservice.com
Jun 09, 2008 | U-Line Icemaker
Refrigerators Logo
444 people viewed this question
Top Refrigerators Experts
Marvin
Marvin
Gil Shultz
