Question about Hitachi Televison & Video
Hitachi HD tv has sound only no picture on HD channels.
Go into settings make sure audio on HD
    Top Expert:
  • Hitachi Master
  • 9,985 Answers
Posted on Mar 14, 2019
SOURCE:
SOURCE: No Non-Hd sound
I had the exact same problem on a brand new Insignia 26 " LCD with DVD. Comcast tech was able to fix it by changing the Comcast box diagnostics. Here is what he did. Using the Comcast remote with the TV on - press power, cable, menu in that order. A comcast diagnostic srceen will appear. Select Additional HDMI options, then audio options. Change the audio options to L-PCM. Press power again to exit the diagnostics. That will fix it and you get to use the HDMI cable.
Posted on Jan 06, 2009
SOURCE: No sound on NON HD channels
  • 59 Answers
SOURCE: Philips HD tv has no picture
common fault this , normally the fuse has failed on y-main board due to shorted thick film unit
unfortunately its not a cheep repair job.
Posted on Aug 18, 2009
  • 308 Answers
SOURCE: I have a Toshiba 32av500u HD LCD TV.NO picture
Its a backlight problem. Common with this model. Under warranty? If not, then its a service shop repair.
Posted on Mar 26, 2010
welcomejee
  • 10594 Answers
SOURCE: my LG HD tv screen suddenly went green. sound is
I disagree with info provided, if screen of your LG lcd tv becomes green that means inverter board is working and lcd tv does not have convergence ICs.
Please unplug tv from ac wall socket for minute to get it reset, replug back in and turn it On and check its picture.
If still showing green screen then change input source with remote, if tv shows same green screen on all inputs that means its either lcd panel problem or digital signal processor got bad loacted on main board. Local tv repairman is needed to confirm and fix it.
Thanks.
Posted on Jul 23, 2010
My hitachi ultrascan hd tvs color is fading ?
Sounds lamp in TV getting weaker and soon it will be replaced.
When dlp tv start showing darker picture then its time for new lamp to get back vivid picture.
Dec 17, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Hitachi 50v500a tv has no picture just blue screen sound works
you might have a bad tuner but in order to confirm that does this happend on all channels? If so then its a bad tiner/decoder and needs to be replaced if it does not happend onall channels you might have a cable no plugged in or loose connections. But please rule out the fact that this is happending on over the aire channels first before assuming the worse.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Sep 22, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Hitachi 53FDX20B -- HD tuner?
hi, hd ready means the tv is capable of re-producing the hd picture from a cable or satellite co. call your local cable/sat people they can advise you which channels are which in your area, video-tek
Jun 06, 2009 | Hitachi 53FDX01B 53" Rear Projection...
I have a Hitachi 53UDX10B 53 in. Rear Projection HDTV.
Hello iehoryna,
The answer is yes, you will be able to pick up and display HD channels. You will have to use your component video cables between your cable box and your TV. Component video will allow you to view low to medium end HD pictures.
I hope this helps,
Thank you,
Shuttle83
Nov 21, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Mounted hitachi plasma tv
The satilite works. The TV won't turn on al all, teied everything.
Nov 09, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Hitachi tv no picture
It sounds like the tuner demodulator has failed. Many times I have found that it is cheaper to buy an external hi-def tuner than repair the one that is in the set. The fact that the tuner is finding channels but not displaying them is a good sign that the demodulator has failed. In one case I had with Sony rear projector, it would have been $800 to repair the internal hi-def tuner and the customer can buy an external tuner for $100-$200. Sorry if this is not the answer you wanted; if you fel this si a good response to your question, please be sure to rate me,. Thanks!
Oct 22, 2008 | Hitachi 26LD6600 26 in. HD-Ready LCD...
Black side bars on hd channels
You may have to refer to the instruction manual for details.
There should be in the menu set-up an option to set the aspect ratio for the different broadcast modes. Normaly, when viewing a 4:3 picture on an HD 16:9 set, the sides will be cut off, otherwise the picture will be stretched or compensated.
Jerry G.
Apr 11, 2008 | Hitachi 42HDS69 42 in. Plasma Television
No sound on hd tv on just one station
put tv on ch 2 and locate MTS button and press it till the sound comes back min English
Electrode.
Nov 23, 2007 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Televison & Video Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
