SOURCE: my pushbutton doorbell activates my neighbor's chime
in the chime box and remote you can change the setting for the remote signal that is picked up( refer to your manual for the correct settings) these will be a set of pin connections in the chime box and in the remote switch that will have to be set to another selection
SOURCE: Chamberlin garage door opener has
1 WIRE WITH RED TRACE
2 WHITE WIRES WITH NO TRACE
3 WIRE WITH GRAY OR BLACK TRACE
ALSO THE WIRE TO THE WALL CONTROL MUST BE WIRED CORRECTLY - DOUBLE CHECK - IT TELLS YOU WHITE AND RED TRACE OR 1 & 2
YES THE POLARITY MATTERS ON THE WALL CONTROL EVEN IF IT LOOKS LIKE JUST A DOORBELL BUTTON.
HOPE THIS HELPS
SOURCE: need to replace tefal actifry
If you were to log on to the
manufacturer's web site, I think you will be pleasantly surprised as
usually one is able to download, if available, by model number,
Customer Instruction Manuals,
and a list of Dealers for
spare parts, as required. Just Google the manufacturer's name and
follow the links. Make certain you are directed to the manufacturer's
web site as some search engines direct you to other sites and they
charge for the information that is normally free of charge. I
hope this helps.
