SOURCE: Jabra BT500
the pin number is 0000, press and hold button until the light stays on to pair with your phone.
SOURCE: jabra bt500
yeah charge it for 14 hours......and then hold the pair and call at the same time... then repeat the pairing process
SOURCE: Jabra BT500 won't turn on or indicate charging
Here is what you do, first get yor headset, hold it up in the air, then grad a hammer and smash it, that should do it.... Hope this was helpful
SOURCE: I'm trying to pair my
I just had this same problem. I solved it by turning the iPhone Bluetooth off and then back on, after which the pairing (with passcode 0000) worked properly and so does the headset.
