The default setting on Brother MFC printer is Fax. Meaning you will usually see the Fax Button lit with a green light. (If the fax button is not lit, just press that button to get it lit.). Put the sheet of paper you want faxed with the side you want sent face down. Now press the OK button. The screen will ask you to enter the Fax number. Key in the Fax number. Press start. The printer will start scanning that page. Once the first page is scanned it will give you 2 options. You can press 1, if you have more pages to send to the same Fax number. or you can press 2. This will tell the printer(Fax) it is just a 1 page document and the machine starts dialing. Wait for the fax completed message. Please make sure that the machine is connected to a working phone line before you start.
hi, HP Officejet 5610 All-In-One InkJet Printerhas few common problems. Such asDriver CD lost,Scanner does not work,Connection problemetc. For find all these software solution just clickhere....
start it up again from the power source, press the menu enter button to get to service , use the < button, under service, press menu/enter, browse to service: restore defaults, press menu/enter twice.
It works, give it about 2-3 minutes to finish rebooting, it will continue flashing and then go away
I had the same problems some months ago. I only solved it when I deleted the printer settings from my computer and reinstalled the software, making sure that I installed all the components from the CD. Also make sure that the printer is on fax default setting when you are using it as fax. You can check this by going to My Computer then Control Panel, then choose Printers and Other Hardware then choose Printers and Faxes. You can then set as default hp Officejet 5500 series fax. Hope these suggestions help.
