Watches Logo
Giwa Femi Posted on Mar 05, 2019
How do i reset the time on my joefox watch - The Watches
carlos sauceda
Level 1:
  • Contributor 1 Answer
  • Posted on Apr 02, 2023
carlos sauceda
Contributor
Level 1:
Answers
Questions
0
Helped
1365
Points
How you fix the second hand is not moving
How to reset the time skmei 1112 watch please?
You appear to be talking about two completely different watches and lumping them together into one good question and one vague question, "reset the time"? Information on both of them.
https://www.google.com/search?q=skmei+1112+watch
https://www.google.com/search?q=watch+WR50M+set+time
Sep 30, 2021 • The Watches
1helpful
How do I change my battery in my joefox watch # 1523 B hands stoped working ? Edward Zubillaga
  • Tip & How-To about Watches
Changing Watch Batteries Lots of posters ask "what is the battery in my (name of watch)" with a view to changing it yourself. This is a bad idea for many reasons. You don't have the tools or knowledge to remove a rotary screw on back, or the gasket sealant for a waterproof watch. Some fashion watches have 4 traditional screw and need professional grade jeweler screwdrivers. Also, there are about 20 batteries commonly used in watches, in various sizes and internal technology, Lithium Ion, Silver Oxide and Manganese Alkaline. If you buy them, you generally have to buy 10!
Don't sweat the details. Just take the watch to your local jeweler. They have all the batteries at hand and the tools to remove the back. It is done whilst you wait for $8 to $15!
Posted by ADMIN... on Dec 31, 2018
Sep 17, 2021 • Watches
1helpful
How do I use the buttons in this QHY watch?
Hopefully, this will help...
Lego Watches Manual Instruction:
There are 4 buttons on this lego watch case, Light button, Mode button, Stop button and Reset button, now I will show how to set the time easily!
1, Light Button: Press this button, the watch LCD light will display for 3-5 seconds;
2, How to use the stopwatches chronograph function?
Answer: When the lego watches in normal working condition, Press "Stop button" for 1 time, then the watch goes into the chronograph mode, then you can use "Stop button" and "Reset button" to operate this function.
3, How to set the alarm time?
Answer: When the lego watches in normal working condition, Press "Stop button" for 2 times, then the watch goes into the alarm mode, then you can use "Stop button" and "Reset button" to set the alarm time, also you can turn off or turn on the alarm function and chime on every hour function by the same operate.
4, How to set the right watch time, hour, minute, second, week, date, month, year?
Answer: When the lego watches in normal working condition, Press "Stop button" for 3 times, then the watch goes into the time setting mode, then you can use "Stop button" and "Reset button" to set the second, minute, hour, week, date, month and year.
This is all. So now please have a try to set your lego watches time!
Dec 06, 2014 • Watches
1helpful
I have a Coleman digital watch. Four button. I replaced the battery and need to reset the time and date.
Click on your watch model number to open the instruction sheet below.
Your model number is located on the caseback of your watch
go here> http://www.gsi-usa.com/instructions/
I bought this watch in May of last year. For the last 3 months, every 2 to 3 weeks I have to reset the hand home position. Once that is done, I have to then reset the home city and time manually. What...
Hand home positioning normally has nothing to do with time setting.
Just set your local time and date and then you can do the hand home positioning procedure.This will not affect the time setting.If hands,after a while,do not show correctly,this means that the watch is under severe magnetic field, after severe shock or finally watch malfunction.
You must know that on this type of watches analog time follows digital time.
1helpful
2answers
I have a 3054. About 3 days ago it reset to 1-1-2005 and has never changed. it now reads 1-3-2005 at 5:57 PM
This same problem (watch resetting to 1/1/205) has happened to me 2x now, about 2 months or so apart.
I have had this watch for ~10+ years now, and works perfectly.
I have replaced the battery 2x.
Again, the watch works great.
I just realized that in the .pdf manual, there is no indication for a "low-battery" condition.
I am guessing that the "low-battery" is what is causing the watch to reset the date/time to 1/1/2005.
Any others having this same problem if this watch resetting to 1/1/2005 after the watch has run just great (auto time syncing, etc.)?
This watch Keeps great time!
Buster Brown
The hands on my Citizen watch (movement caliber number C320) don't reset properly. I have followed the factory instruction several times with the same result: the minute hand moves to a position 5 - 10...
This is normal. The watch begins timing when you reset it. That 5 to 10 minutes is the time that it took you to do the all reset procedure and you can see that the same time is shown in the digital display - so everything is aligned. It is actually pretty cool that it does that. Source: just did the all reset having dropped my watch. Love this watch!
2answers
My husband's watch keeps resetting to 1/1/05 Eastern time. I've reset it a few times and its good for a few days then back to 1/1/05 Eastern. We live in the West and it's 2010 (so he can look at his watch...
Hi,the problem is either from a weak battery or a mechanical fault in the engine of the watch,
i think you should replace the battery,if the problem persists afterwards,then it's time to give him a wrist watch as a birthday gift.
Be cool.
1helpful
I have a DKNY OLED watch, but when I press the button for the time, it keeps resetting itself (both time and date) and no matter how many times I reset the time, it keeps resetting itself. How can I fix...
It sounds like your watch is not coming out of set mode. Make sure that when you are done setting the watch that the display is no longer flashing. This is usually done by holding down the mode or reset button.
If this is not the case then have the watch AC'd. As long as there is no problem with the circuit board this should fix the problem.
My timex watch is not right because the time is 24 hour time and i want to know how to change it to normal time
Select Time reset button (right lower side) until seconds flash
Select Start button on face and cycle through until 24-HR
Select Lap/Reset
Apr 13, 2009 • Watches
Top The Watches Experts
vince
NOEL
NOEL
Paul Carew
Are you a The Watch Expert? Answer questions, earn points and help others
