SOURCE: MITSUBISHI TV VS-60607
Do you get any power indicators? it may be a problem in the powersupply area, or something more serious. Start with checking the fuses there.
SOURCE: MITSUBISHI BIG SCREEN TV MODEL VS-60607 CUTS OFF FOR NO REASON
My mitsubishi 65in projector model # ws65807Just started shutting off it only stays on for few seconds and cuts off. I cant get it to stay on
SOURCE: screen too big for mitsubishi black diamond tv
It was actually a problem with the satellite feed, not the TV. Dish Network was zoomed in, hitting the asterisk button on the dish remote fixed the problem.
SOURCE: how do I reset big screen tv to 1080 on remote
You don't.
It should automatically switch to 1080 when and only when there is a HD signal present. Otherwise it will be in 480 and you will need to use the format button on the remote to change the picture size. If it does not switch to 1080 and you know for sure you have a true HD signal present, there is a problem with the unit.
Hope this helps,
Skyassoc
