Question about Electrical Supplies
I have a new westinghouse gen. 7500w. It has had trouble starting in the cold weather.
I changed the oil to 5w-30 and fully charge battery. The choke is functional. If I let it set for a few hours the battery doesn't start it unless I recharge it even though battery show it has charge. Something seems to be draining the battery enough that it doesn't have enough cranking amps to start!
  • Electrical S... Master
  • 1,346 Answers
Battery drain after shutdown must be a featrue?
STOPPING THE GENERATOR Normal Operation During normal operation, use the following steps to stop your generator: 1. Remove any connected loads from the control panel receptacles. 2. Allow the generator to run at "no load" to reduce and stabilize engine and alternator temperatures. 3. Position the engine control switch to STOP or if you plan to store the generator after use, turn the fuel shutoff valve to the OFF position and allow the fuel to be consumed from the carburetor. 4. For Push Button Start models if you plan to store the generator after use push the Battery Disconnect button in so it stops drawing power from the battery
Posted on Mar 05, 2019
    Top Expert:
  • 25,065 Answers
If its new id be looking for warranty help. is this a standby or a portable?? standby has a built in trickle charger to keep the battery good when sitting idle...for what its worth it could be a generac unit
SOURCE:
  • 40 Answers
SOURCE: Wont start when weather is cold.
Tune up... its flooding when its cold due to the plugs being worn out...
Posted on Nov 25, 2008
  • 6982 Answers
SOURCE: 2001 chevy silverado 1500 v8 battery drain after sits for 1or2day
, do a simple test on the charging system...check battery voltage. should be 12v or better. start engine & check volts at idle, no accessories on. volts should read 13.5 -14v. Turn on all accessories(including headlamps on high) volts should drop slightly but should not creep down. Definitely not below 12.5. If voltage drops lower than 12.5, the regulator (in the alternator) is not working. either change regulator or change entire alternator. Alternator drive belt should have sufficient tension so that alternator cannot be turned easily by hand. If it can, check belt tensioner.
Posted on Mar 18, 2009
CaptainKeyz
  • 202 Answers
SOURCE: What cold cranking amp rating should the battery be ?
It should be enough for that size engine. That is 550 AMPs for 30seconds in 0 degrees. Most cars have batteries twice the power than they need. It helps run the accessories like lights and radio. If your car has trouble starting right away, you may want to get the strongest one that you can fit in there. If it runs fine, then I wouldn't worry about it.
Posted on Feb 01, 2010
  • 5692 Answers
SOURCE: 2001 ford focus will not start. The engine will
I will try to help you. You are correct about the starting fluid, if it has fire starting fluid should do something. So the problem must be either no fire to the plugs or the timing belt is broke.
Check to see if the plugs have spark. If they do not, then get with the Autoparts store and ask if your car needs a Ignition relay to run. Then ask if your car takes a rubber timing belt. If your car does not have a rubber timing belt try the Ignition relay. If you do have a rubber belt check behind the shield in front of the engine to see if the timing belt is broke.
The timing belt is different than the serpetine belt that drives the pulleys. Cars with rubber timing belts have both belts. Should your timing belt be broken it is not an expensive repair. But you will need to details on replacement of that part.
Posted on Apr 18, 2010
Testimonial: "I appreciate your help and will be checking your sugestion very soon."
SOURCE: 2004 F150 4.6 won't start
Did anyone have a soluction to the above problems?
I have the same issue on 2005 F150 with 5.4L engine.
Posted on Feb 02, 2011
Oil&filter change on Briggs&stratton IC quiet OHV14.5 hp engine.What kind and how much oil? What type of filter?
Oil Recommendation
  • SAE 30 40° F and higher (5° C and higher) is good for all purpose use above 40° F, use below 40° F will cause hard starting.
  • 10W-30 0 to 100° F (-18 to 38° C) is better for varying temperature conditions. This grade of oil improves cold weather starting, but may increase oil consumption at 80° F(27° C) or higher.
  • Synthetic 5W-30 -20 to 120° F (-30 to 40° C) provides the best protection at all temperatures as well as improved starting with less oil consumption.
  • 5W-30 40° F and below (5° C and below) is recommended for winter use, and works best in cold conditions.
May 15, 2018 | HP Measuring Tools & Sensors
My yd25 engine starts hard when its cold what causes that
Oil can cause it or it could be the battery. Normally in cold weather you want a thicker viscosity like a 10w-40 and in the summer you want a thinner viscosity like a 5w-30
You can change the oil so its a little thicker if its that cold in your area. I don't know were you live but if your reaching the cold weather like in the 30s in the morning then changing the oil to a thicker oil could help.
Or a cheaper first try is to test that battery you have its cold cranking amps could be failing on you. So this is what you want to do;
If you got a battery jump starter you could try that in the cold morning and test it that way and see if it starts if it does then its the battery.
Hope that helps if it don't let me know.
Sep 28, 2014 | 1998 Nissan Frontier
What grade of synthetic oil does my 2003 vw new beetle take
IF YOU HAS GAS ENGINE USE API CERTIFIED FOR GAS ENGINES USE 5W 30 FOR COLD WEATHER. YOU CAN USE 5W 40 FOR WARM AND HOT CLIMATE. FOR DIESEL ENGINE YOU NEED API SERVICE CF4 OR CG4 USE MOBILE 1 OIL 5W 30 COLD WEATHER AND 5W 40 FOR HOT CLIMATES ALSO CHECK IN OWNERS MANUAL.TO BE ON THE SAFE SIDE OR ASK THE AUTO PARTS SALESPERSON TO LOOK UP TYPE OF OIL YOU SHOULD USE TO KEEP FROM DAMAGING THE ENGINE IF YOU HAVE TURBOCHARGER.
Apr 12, 2011 | 2003 Volkswagen New Beetle Convertible
2003 Chevy Trailblazer V-6 4WD. I just got the oil changed. I think I made a mistake and told them to put in 10w-30 instead of the 5w-30 that the vehicle was used to. Since then, my SUV has been sputtering...
CHECK YOUR OIL DIP STICK MAKE SURE YOU HAVE ENOUGH OIL IN THE CRANKCASE.YOUR ENGINE CALL FOR 7 QUARTS OF OIL. IF YOU HAVE THE INLINE 6 CYLINDER.CHECK OIL LEVEL ON DIP STICK.YOU SHOULD BE AT FULL MARK.AND NOT ON THE LOW MARK.IF SO YOU NEED ADD LITTLE MORE OIL TO GET TO THE FULL MARK.YOU CAN USE 10W 30 FOR SPRING AND SUMMER WEATHER. 5W 30 FOR COLD WEATHER COLD CLIMATE.I RUN 10W 30 YEAR ROUND IN ALL MY NEW CHEVY AND OLDSMOBILE VECHICLE HAD NO PROBLEMS.IF OIL LEVEL CORRECT YOU COULD HAVE FUEL PROBLEMS.COULD HAVE STOPPED UP FUEL FILTER, BAD GAS,
Apr 12, 2011 | 2003 Chevrolet TrailBlazer
What grade and weight oil is used for 1995 Nissan Sentra with 4cyl?
In cold weather, use 5w-30, in warm weather, use 10w-30.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Mar 12, 2011 | 1995 Nissan Sentra
Engine oil capacity & type
Visco 2000 or mobil oil, use the dipstick to check do not let it be too full.
The type specified by the vehicle manufacturer in your owner's manual. For most passenger car and light truck gasoline engines today, it's any oil that meets the American Petroleum Institutes "SH" rating.
As for the viscosity of oil to use, most new engines today require a multiviscosity 5W-30 oil for all-round driving. The lighter 5W-30 oils contain friction reducing additives that help improve fuel economy, and also allow the oil to quickly reach critical upper valvetrain components when a cold engine is first started. Most engine wear occurs immediately after a cold start, so it's important to have oil that is thin enough to circulate easily -- especially at cold temperatures.
For older engines and ones that are driven at sustained highways speeds during hot weather, 10W-30 or 10W-40 is a good choice. Heavier multiviscosity oils such as 20W-40 are for high rpm, high-load applications primarily and are not recommended for cold weather driving.
Straight weight 30W and 40W oils aren't very popular anymore, but some diehards insist on using them. They say the thicker oil holds up better under high temperature (which it does), increases oil pressure and reduces oil consumption in high mileage engines. But straight 30W and 40W oils are too thick for cold weather and may make an engine hard to start. They may also be too thick to provide adequate start-up lubrication to critical upper valvetrain components during cold weather. So switching to a straight 20W oil would be necessary for cold weather driving. Straight 10W oil can also improve cold starting, but is very thin and should only be used in sub-zero climates. A multiviscosity 10W-30 or 10W-40 will provide the same cold starting benefits of a 10W oil and the high temperature protection of a 30W or 40W oil.
For the ultimate in high temperature protection, durability and all-round performance, synthetic oils are the way to go. Unfortunately, most synthetic oils cost up to three times as much as ordinary petroleum-based oils. They cost more because synthetics are manmade rather than refined from petroleum. But this improves their performance in virtually every aspect:
  • Superior temperature resistance. Synthetics can safely handle higher operating temperatures without oxidizing (burning) or breaking down. The upper limit for most mineral based oils is about 250 to 300 degrees F. Synthetics can take up to 450 degrees F. or higher. This makes synthetics well-suited for turbo applications as well as high rpm and high output engine applications.
  • Better low temperature performance. Synthetics flow freely at subzero temperatures, pouring easily at -40 or -50 degrees F. where ordinary oils turn to molasses. This makes for easier cold starts and provides faster upper valvetrain lubrication during the first critical moments when most engine wear occurs.
  • Better engine performance. Synthetics tend to be more slippery than their petroleum-based counterparts, which improves fuel economy, cuts frictional horsepower losses and helps the engine run cooler. The difference isn't great, but it can make a noticeable difference.
  • Longer oil change intervals. Because synthetics resist oxidation and viscosity breakdown better than ordinary motor oils, some suppliers say oil change intervals can be safely extended -- in some cases stretched to as much as 25,000 miles. Such claims are justified by the fact that synthetics don't break down or sludge up as fast as ordinary mineral-based oils do in use. CAUTION: For vehicles under warranty, extending the normal change interval is not recommended because failing to follow the OEM's maintenance schedule can void your warranty.
    Synthetics are available in the same grades as ordinary motor oils (5W-30, 5W-20 and 10W-30) as well as "extended" grades such as 15W-50 and even 5W-50.
    There are also lower-cost synthetic "blends" that combine synthetic and petroleum-based oils in the same container. But you can do your own blend to save money by simply substituting a quart or two of synthetic oil for conventional oil when you change oil. Synthetics are compatible with conventional motor oils.
    Who should use a synthetic oil? The premium-priced oil is best for:
    • Turbocharged or supercharged engines
    • Performance or high output engines
    • Vehicles used for towing (especially during hot weather)
    • Vehicles that are operated in extremely cold or hot climates
    • Anyone who wants the ultimate in lubrication and protection
Take care and good luck
Dec 03, 2010 | 2008 Nissan Xterra
I Don't know what type of oil to put in my 1992 honda accord
This is right from the owner's manual: Recommended Engine Oil: API Premium grade 5W-20 detergent oil . 5W-20 oil is formulated for yearround protection of your Honda, to improve cold weather starting, and to help your engine use less fuel. If 5W-20 oil is not available, a 5W-30 oil may be used. However, it should be replaced with 5W-20 at the next oil change. ---------- for more help in how to change oil and oil filter in your Honda car please click the link below. https://techinfo.honda.com/rjanisis/pubs/om/AC0202/AC0202O00250A.pdf Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Jul 02, 2010 | 1992 Honda Accord
Will turn over but not start in cold weather
could just be the oil if you are in a really cold environment (near or below 0), make sure to use 5w-30 versus 10w-30 which is suited for warmer climates..
Jan 06, 2009 | 2002 GMC Envoy
Electrical Supplies Logo
47 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
