SOURCE: The riser on my Tunturi T20 is stuck on maximum
Phil, I have had the same problem today.
did you solved the problem already?
SOURCE: False Elevation Edge 705
I have exact same problem. It has been working for 5-6 months but suddenly on one trip it now reads app. 280 meters too high elavation
SOURCE: my treadmill is stuck on elevation error. I tried
Hi ewalker99, did you ever find a solution to this problem. My Sole is doing the same thing. Thanks!
SOURCE: Imaginext batcave elevator string came out
I had the same issue, my son used his all of half a day and the elevator stopped working. If you take the top of the cave off, and unscrew it from the elevator shaft you will see a black wheel. The string needs to be wrapped around this twice, there should be very little play in the string. What I had to do was take out the 3 screws that held it to the knob on top, then wrap the string back around the wheel making sure not to tangle the string more. once the string is wrapped 2 times you can reassemble.
