Either remove filter from bottom of dryer if it has one, remember to put a towel or something to contain spillage or if no filter take off back panel and remove hose on pump motor again allow for spills.
Most of the time the problem is in the drain hose being blocked from debris. Check where your disposal meets the drain hose and be sure it’s not clogged. It is normal for it to leave a small amount of water in bottom
One way is to reset and start the dishwasher for a few seconds. Most dishwashers turn on the pump for a quick burst to remove the standing water before the unit adds fresh water.
Another is if you are going to do a repair or clean-out use a turkey baster to suck out the remaining water. Even high end dishwashers leave a small amount of water in the sump until you do the next wash.
Hi
Dishwasher not draining issue usually occurs due
to kinked drain pipe, clogged drain filter or drain pump. First make sure that
the drain is not clogged and remove clogs if present. If no visible lint is
present then remove the lower front access panel to check the drain filter and
drain pump for any clogs, you'll need to clean the drain filter and drain pump
completely. Also, check for any food pieces stuck near the pump impeller &
clean the chopper assembly. Please note that dishwashers don't drain out the
complete water such that heating element doesn't overheat. Hope this helps...
Please post back for any further assistance.
Daniel
Hi
Daniel
