Question about LG Dryers
LG TROMM DLG7188RM dryer, i opened the dryer to replace 2 rollers that had gone bad and once i put it all back together i tried to test it and the lights turn on but now it has the check filter flashing and when i press the play/pause button the dryer wont start moving at all it only stays with the play/pause flashing and the check filter flashing
  • LG Master
  • 2,472 Answers
I'm guessing the drive belt is incorrectly installed. It needs to hold the tightening pulley at tension. The belt goes down from left of drum to clockwise around the pulley them around the drive motor. Push up on pulley to install. Answer if you need more info. Only way to do this is to take it all apart again. You may be able to leave the fron roller assembly on to reach around it. Good luck.
Posted on Mar 07, 2019
  • 7 more comments
  • Ruben Ruiz Mar 22, 2019
    I ordered a new belt and i called a repair guy to come install the new belt and see if with him putting back the belt the right way might fix the problem and it did not it still does the same,the dryer lights turn on but when i press the play/pause button it wont start spinning
  • robert Mar 22, 2019
    Well if it all worked before then the only issues I could see is: 1. The belt to engage the motor trip switch, 2. The control board connectors not full engaged, 3. The door switch not plugged back in fully. Good luck.
    By the way, is the interior light on when you try to start dryer?
    Yes sir the interior light stays on when i try to start the dryer
    Then the door switch is not closed. Try putting something on the door or the button of the switch so it pushes in more. Otherwise The switch is bad or not plugged in.
  • robert Mar 24, 2019
    Did you get it running.
  • Ruben Ruiz Mar 24, 2019
    I ordered a new door switch
    It has 3 wires and one of them number 3 looks burned
    Let us know when you get it and install it, what the results are. Thanks
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 37 Answers
You probably never noticed it before. This is normal.
Posted on Apr 16, 2019
    New Friend:
  • 31 Answers
Maybe you knocked out a sensor plug wire?
Posted on Mar 22, 2019
SOURCE:
SOURCE: Dryer won't work, Check Filter light is on
I had exactly the same problem with my newish LG dryer. I deduced that the dryer's computer essentially needed to be rebooted. I pulled the plug for a minute or so, then plugged it back in. It works perfectly now.
Posted on May 06, 2007
Healeyman
  • 1198 Answers
SOURCE: start button doesnt start the dryer
Sure sounds like a door switch to me. Is anyone slamming the dryer door? Was there a rubber bumper on the door that is now gone?
Posted on Apr 24, 2009
cherylogle
SOURCE: lg tromm dryer electric cooling light staying on
I called LG after seeing this light as well and they say it's supposed to stay on and should "blink" at the end of the cycle. I've never remembered this light staying on in all the years of owning this machine but she (LG rep) said it was normal. Otherwise, if you've checked everything and it's not drying clothes, you may need to have your dryer serviced. :(
Posted on Dec 14, 2009
PSITECHNICAL
  • 71 Answers
SOURCE: check filter light wont shut off and setting.lg tromm dryer
You might need to check the exhaust on the rear of the Dryer, or the blower motor iether one has lint inside, restricting the air flow
Posted on Dec 23, 2009
SOURCE: my lg tromm DLG69885 gas dryer is not heating; oth...
I am using LG Tromm DLE2514 washer dryer. It 's running but didn't dried the clothes. I clean it's lint but still it's not working. The one thing i notice now is it's drying light is blinking and cooling light is turn on all the time during the cycle. So what's the problem with my dryer?
Posted on Jul 04, 2010
After replacing rollers on a LG TROMM DRYER. it won't spin
I would check to see if I put belt on right. There is a belt switch the must engaged. Also is the door switch plugged back in?
Feb 07, 2015 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Lg tromm dryer
You need to replace the bell, also check those roller underneath of the drum are freely turn. It is quite hard to take off the front door of LG dryer, if you not a handy person, call for service. If you want to try let me know, I will guide you to open it.
Oct 16, 2013 | Dryers
Tromm dryer
I don't know if your warranty is up but its covered if not. I have gone and swapped out dryers for same problem and they were LG's and It always seemed.to be those rubber wheels
May 29, 2013 | Dryers
Dryer struggling to turn and making noise.
first off send the brand name and model number off of the dryer open the door and look around the opening where you put the clothes in and you'll see the model number.there is only one belt,you could have a bad roller,or a bad belt pulley or something in the blower wheel from running the dryer with the lint filter out,something can go down where the filter goes and get into the blower but the only way to tell is by getting in there,if you need help send info or go on utube and put in your model and brand name,there's tons of videos out there on taking apart dryers.
Feb 07, 2018 | LG Tromm Electric Dryer
I have an LG dryer Model # ddle7177rm/dlg7188rm.when we start the dryer it starts to heat then stops and it blows cool air. the ducts are all clean.
Hello
As everything in your dryer is working fine apart from it heating properly so the recommended repair will be thermal fuse/thermostat replacement. However, you can also test its continuity before replacement. Please get back to me if you have any other questions.
Kevin
Dec 02, 2010 | LG Dryers
Cracked drum lg tromm dle2512w dryer. is it worth replacing? dryer is about 3 yrs old
I'd say yes, especially if you replace it yourself to avoid a service call. Top needs to come off (screws at back, then push top back 2 inches and lift off), remove front, remove 4 screws holding front bulk head / front rollers, slip belt off tension pulley, remove drum, reverse to install.
Sep 25, 2010 | LG DLE2512W Electric Dryer
Lg dlg 7188rm gas dryer will not heat
Check to make sure that the thermal fuse is not blown. Small plastic piece with 2 wires coming off of it. Typically this is problem.
Feb 01, 2010 | LG DLG7188 Gas Dryer
I have a front loader LG Tromm dryer that has a crack in the drum. Can this be self repaired anad if so how? Thanks
I HAVE REPLACED SEVERAL OF THEM. THE ROLLERS CAN GO BAD AND THE TUB IS SUPER THIN. IT USEUALLY CRACKES AT THE WELD IN THE BACK. THERE MAY BE A RECALL ON THAT BY NOW. THE LG COMPANY MIGHT SEND YOU A NEW TUB AND ROLLERS IF YOU COMPLAIN TO THEM ENOUGH. UNTIL THEN ALUMINUM TAPE IS A TEMPORARY REPAIR
Nov 03, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
I have had bad allergies and stinky clothes
Ihave the same problem and my husband thinks its something i'm doing wrong.I did switch to he detergent and it helped for a while.Now it's doing it again.I just cleaned all the rubber pieces with bleach water and hopeing it will help.But truthfully i can't wait for this thing to die so i can get a new washer.and it will not be a front loader.....
Jul 18, 2009 | LG WM2688HWM TROMM SteamWasher
I need to replace roller's on LG Tromm Gas front load dryer
There are 4 screws holding on a plate on the back. It is not the whole panel. Are you trying to get at the ball sensor?
Feb 24, 2009 | LG WM-2277HW Front Load Washer
Dryers Logo
59 people viewed this question
Top LG Dryers Experts
jimorris77
Craig Butler
Craig Butler
Marvin
Marvin
Are you a LG Dryer Expert? Answer questions, earn points and help others
