Washing Machines Logo
H
Helen Ciavarella Posted on Mar 05, 2019
Model WAW28460AU. After each wash, why is there water in the rubber seal?
I don’t know how to fix this
5 Related Answers
hattonhall
Poppa Maddo
  • 372 Answers
  • Posted on Aug 30, 2007
SOURCE: Maytag Performa Washing Machine
Before you do anything else..UNPLUG it from the 240volt supply ! Read ALL of this before attempting the fix. After draining out the water, lay the machine down to expose the inner workings. You'll need to find the pressure switch which is connected by an thin rubber or plastic tube from the wash tub. Check that it is is properly connected.(YOu may have to cut off a little of each and to give you a an "as new" airtight sealed fitting. A little smear of quikgrip glue around the nozzle at each end will ensure a longlife airtight fit of the tubing.) BUT before you do the final glueing and fitting of the tube. Just have the tube at the pressure switch nozzle connected and BLOW into it. You should hear an audible click when blowing and relesing the air. Even if you hear this, it only confirms that the diaphragm in the pressure switch is ok. It does not tell you if the two way switch inside it of good integrity. By integrity I mean the condition of the switching CONTACTS, As they carry high current, they eventually burn and pit and can become of such HIGH resistance to the flow of current that there is none when the switch is in fact physically in the on position. Further advice from me can be had by accessing the PAYG "Let our Experts Solve YOur Problem" FixYa Link.
Anonymous
  • 41 Answers
  • Posted on Feb 29, 2008
SOURCE: Washing machine rubber door seal replacement
Go to www.Searspartsdirect.com You should be able to find an exploded view and parts list
neale duncan
  • Posted on Apr 06, 2008
SOURCE: replace rubber seal on my zanussi washing maching
the only way to fit door rubber to tub on a zanussi is to use washing up liquid it takes two mins
Anonymous
  • Posted on May 11, 2008
SOURCE: Frigidaire washing machine collects water behinf door seal
Frigidaire has several mfr defects with their new front loading machines. The detergent/bleach drawer retains water, the door often leaks, water does accumulate in the door seal and the spin has broken twice on us and the machin is only 15 months old! Repair is contracted out by Lowes to independant repair companies, who demand payment, even when Lowes says it is covered under warrantee. What a waste of a large amount of money! We will NEVER purchase Frigidaire or recommend their products to anyone.
A
Anonymous
  • Posted on Aug 31, 2008
SOURCE: fixing new rubber door seal
have Maxx bosch machine trying to replace robber door seal. Can you advice how to do this as having difficulty with spring retainers
Picture of the drain filter on the front of a LG washer
There is a video here. They are normally a plastic plug with a rubber seal. You turn the handle in the centre which makes the rubber seal expand to seal the plug.
https://www.google.com/search?q=drain+filter+on+the+front+of+a+LG+washer
Please always include full model details. The manuals are normally online.
Water escaped the torn rubber seal (I know, I know shoulda had it fixed before using but again but it is sooo expensive and this is our third seal!!!) and leaked I suppose inside. Now my waterproof s
I would consider having a service person come in and repair it, you have already spent a good portion of the cost on seals to no avail. There might be a simpler answer but without knowing make and model we are at a loss.
Water is coming out of top washing machine.The wateris not overflowing.It looks like I see lintclogged at the top of the drum'How do i take the top off to clean it.I have a whirlpool model LSR5132the last...
Ignore the lint, it wont cause a leak. The shiny wash drum gets wet, so it sits in a sealed outer drum that contains the water. The water can only get out of it at the front where their is a rubber seal around the door, or through broken bearings at the back. Is the water coming out at top front or top back? Front seal fix is easy, but changing rear bearings takes me 4 hours.
2helpful
Ripped Door Seal
yes not a problem give the make and model to your local appliance spares shop and they will more than likely have one in stock if not try on line let me know when you have found one and i will guide you though fitting it
Hoover optima washing machine is leaking very badly . I have stripped the machine down and cannot find the leak . Inlet pipes clear. Cleaned soap drawer and two feeder rubber pipes don't seem to be a...
Hi,maybe the draw dispencer is damaged,I wouldnt think it is the drum seal,what I would do is tilt the washing machine so that the top of the machine is leaning against the wall so that the front of the machine is of the ground,then while you get underneath the front on the floor with a torch get someone to put water in the dispencer and see if you can see where the water is leaking from,I hope this was some help,all the best.
Piece of rubber came out torn. water leaks out
door seal must have hole in it replace hole at bottomof seal
Loud rubber squeal sound with new clothes washer water seal.
its the wrong seal. do not lubricate it at all rubber sweals with any kind of petrolium product. many door boots look right for the model but will be thicker then needed. and will cause rubber to hit the basket.
2answers
Rubber seal has a rip in it
We had to replace our seal and it was about $250.  The tech told me that when you wash socks-put them into a garment bag.  He said it is hard on the seal.  Also he said that when washing comforters to wash it on the delicate cycle because regular washing is hard on the seal.  I wished I would have know this before hand :-(
Top Bosch Washing Machines Experts
NOEL
NOEL
Oliver Street
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
