Computers & Internet Logo
Zarah Bolneo Posted on Mar 05, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Im using a usb type headphone/microphone and the laptop model emachines d725 cannot detect the headphone that i inserted, can you help me,need it badly
Larry Ng
Level 3:
Top Expert:
  • eMachines Master 14,598 Answers
  • Posted on Jan 22, 2022
Larry Ng
eMachines Master
Level 3:
Top Expert:
Answers
14598
Questions
0
Helped
3278770
Points
66616
NO OS told, at all, we can not guess OS.
came with windows 7 , is it still? if upgraded ports die.
GL40 chip set is frozen at w7 max. forever.
2006 CPU , is not supported above w7 as Intel stated. endless.
is it windows type winver in run box or control panel + system.
do all usb ports work with a usb mouse , or keyboard or USB thumb driver? if not the USB ports are dead.
if buying usb head phone ask them for w7 support, as many ended that now.
if not running w7, (not told) then your ports are dead. or the phones do not support the unstated OS.
see how hard I worked top answer , lacking NO OS told?
drivers must match the OS and be available .
5 Related Answers
Anonymous
  • 5 Answers
  • Posted on Nov 10, 2007
SOURCE: Logitech USB headset no sound
Have you tried changing the Audio Device that windows is using?
Under the Sound and Audio Devices in the ontrol Panel. Under the Audio tab, try the Default Device under Sound playback. Change this to the headphones.
Anonymous
  • 238 Answers
  • Posted on Feb 14, 2008
SOURCE: My external microphone jack and USB's doesn't work on Toshiba Satellite
hi, double click on the speaker icon on the bottom right corner, go to options, recording and select the microphone and adjust the level suitable.. thats it.. let me know
Anonymous
  • Posted on Feb 20, 2008
SOURCE: Iam unable to call my frends through yahoo messenger by using logitech usb type headphones on mythoshiba laptop
Go into your sound controls and disable any other playback/recording hardware besides the logitech headset. Yahoo will still mute the headset but you can put the volume back up and start using it. Cheap work around but it works for me. I found that when using the headset, yahoo was trying to use my onboard sound devices instead of the headset.
Anonymous
  • 58 Answers
  • Posted on May 11, 2008
SOURCE: cmos checksum bad...usb current status detected system shut down 15 sec
Situation Remedies If you have encountered this error and would like to fix your computer, here are some remedies for each situation:
CMOS Battery Not Functioning Properly: If you suspect your CMOS battery is not functioning properly you can easily change it. Before changing your battery, reboot your computer to make sure that the error still exists. If it does, go into your CMOS and write down all of the settings. If all settings are lost, you can usually get them from your computer manufacturer. Now locate the battery and remove it, you might need to consult your computers manual or tech support to remove your battery. Take down the CMOS batteries information such as volt, size, etc. Once you have your new battery, you can replace it and reenter your CMOS settings. If your battery was the cause of the CMOS Checksum Bad Error, you should have remedied the problem.
Your BIOS has Been Updated (either by you or possibly a virus): If your BIOS has been updated recently, your CMOS settings may have become reset. Make sure that the values entered in the BIOS are correct or simply reset them to the default settings. If you believe that a virus updated your BIOS settings, run a virus scan and make sure that the BIOS settings are back to the default.
The Computer Was Shut Down Improperly: Sometimes when running MS Windows, if you shut down your laptop or desktop without first properly shutting down your operating system it will corrupt the CMOS settings causing the CMOS Checksum Bad Error. You can easily avoid this error by making sure that you completely shut down your computer before turning off the power. Usually this entails going into the Start Menu/ Turn Off Computer/ Shut Down. If you received the error, shut down the computer properly, if this is the cause of the error, the error message will not return.
Anonymous
  • Posted on Jun 29, 2010
SOURCE: please....my emachines d725's microphone isn't
After downloading every possible driver and tweaking every possible adjustment I have come to this conclusion: There is NO built-in microphone on the eMachines D725! Oh, the Device Manager will show it, all right but I assure you, there is no built-in device that can pick up sound on that laptop model. You'd think that a laptop, albeit a budget on, with a built-in webcam should also have an accompanying built-in mic for messaging and calls, but it doesn't. The mic may have fallen by the wayside during the cost-cutting sessions, along with the 3rd and 4th USB ports. Your only options are to connect an external microphone or to trade the D725 for a real laptop.
How to reset bios password emachines d735 series?
I think you mean D725, not D735. I don't think that there is an eMachine D735 model.
The D725 series is a laptop.
Unfortunately, there is no easy solution.
You will need to open the laptop, if you know how to do the reset.
First disconnect your machine from power; this is an important step (otherwise the next step won't work); then open the laptop.
Be very careful not to cause damage with static electricity from your body.
After you open it, remove the CMOS battery for 20 to 30 minutes.
That will make the motherboard forget all the CMOS settings.
Reinstall the battery and try to boot-up.
There used to be a software utility toolkit to reset the BIOS password, but it has now disappeared from the Internet because it could easily be used for illegal purposes.
I hope this helps a little bit.
Install built in microphone for d725 emachines laptop
it does not have a built in microphone, you ahve to install external one :)
Does emachines e627 have a microphone?
this is from the emachines website http://support.gateway.com/emachines/notebook/2009/emachines/eme/eme627/eME627sp2.shtml
Peripheral Subsystem
Integrated webcam, 0.3-megapixel resolution, featuring enhanced technology for low-light environments
5-in-1 card reader , supporting MMC, SD, xD, MS, and MS PRO cards
Built-in microphone
Two USB 2.0 ports
External display (VGA) port
Headphone/speaker/line-out jack
Microphone-in jack
Ethernet (RJ-45) port
DC-in jack for AC adapte
When I skype, I can hear them but they can't hear me. What to do? I have an Acer eMachine D725. Is a microphone already installed or do I need to buy one? Please help in terms I (a novice) can understand....
Go into Skype
Tools
Options
Audio
Set your microphone to the one you want to use.
Test it by calling out and watching the green line move across the scale.
1helpful
Do acer emachine D725 has built in microphone?
i think there's none..i own the same model..and i believe there's none...
2helpful
Microphone and wifi
The eMachines D725 Notebook does not have an inbuilt microphone in it.But it does have the Microphone-in jack to which you can plug in an external microphone.Even though it comes with an Integrated webcam ,you have to use an external microphone for chat.
4helpful
2answers
Is emachine D725 has built in microphone???
Ye s the past eleven years they all do have a mic installed. Look for a very small hole surrounding the keyboard for it will be inside there
6helpful
4answers
Please....my emachines d725's microphone isn't working..help please!
Mic
If your headphones have a single plug you cannot plug these into a regular speaker connection or headphone connction and get mic and sound, you will need a headset that has 2 separate plugs (one for Mic and one for headphone) or a splitter you can get a radio shack. Most headsets have only one plug and there are connections for both the mic and the headphones on this plug, but the headphone connection on the computer has only connections for the headphone and therefore cannot detect the microphone.
Top eMachines Computers & Internet Experts
Andrew Chrostek
Andrew Chrostek
Level 1 Expert
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
