Question about LG Televison & Video
My LG PDP60X70000 has an issue with the display and sound. When I switch it on I just get clicking.
I've been able to consistently fix the issue by unplugging both the powerboard and the Y-sus board whilst in standby mode red light, then I turn it on once with the remote that gives me sound, turn it off with the remote and back on that gives me sound and picture. Any thoughts on what is wrong
SOURCE:
  • 1894 Answers
SOURCE: panasonic th-42pa20 plasma 42 inch tv
was that capacitor damaged?
Posted on Jan 11, 2008
SOURCE: lg plasma 50px4d-eb keeps going into standby mode
good grief - my TV just did the same thing - its locked in standby mode - I disconnected power several times - each time i reconnect the green light comes on for about a minute 9nothing happens on the screen) and then returns to the stanby mode
Posted on May 18, 2008
  • 1348 Answers
SOURCE: When i on the tv by remote the red standby light
the high voltage or flyback transformer is not working.the sound runs off a separate fixed power supply.if you run your hand across the screen,is there static?that would mean the high voltage is ok but there is another circuit fault
Posted on Jul 08, 2009
dsacco86
  • 1077 Answers
SOURCE: 42 LG plasma no picture but sound. found internal
Sounds like it started "Protection Mode" because of a failed electronic part inside the TV. When this happens, the TV will keep turning itself OFF or will not turn ON at all. This keeps the other parts inside from being damaged. Most likely the TV has a power supply related problem. The common part to go bad for flat panel screens circuit board that powers the screen itself. Most manufactures call it a Backlight Inverter Board.
But, I can't say what is 100% the problem because I can't actually look at the tv over the internet. I can only make guesses with the symptom.
You have a few choices:
1. Best thing to do, if you can find and purchase a Service Manual over the internet; It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, schematics, test points, and part# lists.Usually, cost under $20. Its the best repair guide material for fixing TVs. And most cases the new part cost less than $15 by searching on the internet with the part number.
2. Pay a TV shop to do the repairs. It maybe costly, but get an estimate of how much they will charge. That way you can decide if it worth repairing or replacing the whole TV.
I hope I shed some light on the subject for you.
Posted on Jul 21, 2009
Bulldog AV
  • 52 Answers
SOURCE: after turning ON the power/standby switch, the
Is the red light flashing at first?
The unit may be going into protect mode. Lets hope it has done the job and the receiver has protected itself from failure.
Protect mode can result from speaker wires touching each other or the Amps2_bing.gif metal case. Check that first.
It can also be caused by unstable ohm loads if too many speakers2_bing.gif are connected to any of the outputs especially zone 2.
If you can remove all speaker wires and turn the unit back on. If it stays on, turn the volume down on the main zone and zone 2 if connected. Then reconnect speaker wires.
Posted on Nov 24, 2009
Lg blu ray player resetting
Hi Jamie,
I had this issue on my LG blu ray player before and found a fix. Link is attached, but here is the summary of the issue: Turns out is was an audio issue that causes the restart. Quick fix is to hit the audio button when the movie starts (near the bottom of the remote) and use the ">" button to change the audio to "2 Eng" (2.0 CH). It's the TrueHD audio of 1.0 CH that causes the system error. I believe you may encounter this on a few other recent Disney releases with TrueHD audio (not sure if your disc is from Disney as well). Not sure if there is a firmware update to fix this, but it's worth a shot to call the 1-800 number on the top of the player. (1-800-243-0000 LG Support)
Hopefully this fix works for you and others experiencing the same problem!My LG Blu Ray Player shuts down when playing specific disc
Apr 23, 2014 | LG Bp125 2D Slim BRay Player - Black
I've a problem with my pc ProBook 4331s, when i switch on it does not display anything in a screen, please help me
If your laptop appears to boot up and the hard disk LED flashes, then the problem is probably a back light fault. This can be a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Apr 20, 2013 | Computers & Internet
My CD drive doesn't work
Your display adapter is the component of your computer that allows your monitor to work. On the operating system side of things, this display adapter is controlled by a device driver. If you're having issues with your display adapter (like colors are displaying incorrectly or the screen is flickering), you can fix these problems by rolling back your device driver using the Windows Device Manager.
Open your Control Panel by clicking "Start" and then "Control Panel." Click "System." Click "Device Manager." Scroll down to the "Display Adapter" heading. On a single monitor setup, there will only be one device listed under "Display" adapter. Right-click it and click "Properties." Click the "Driver" tab. Click the "Roll Back Driver" button. This will uninstall your current display adapter driver and reinstall the last version that worked properly. This will fix the issues you were having with the device. Hope this helps
Jan 16, 2013 | Acer Aspire 5735 Notebook
Toshiba Satellite A505 - Most of the time when I turn it on the screen is grey, with no text.
This sounds like a bad display on the laptop. Hook up an external monitor to the vga port on the laptop. You may need to toggle the display to output to the external monitor. This is generally accomplished by pressing the "FN" key + one of the F# keys. Look for an icon that resembles a monitor or it may say LCD. If the graphics display correctly on the external monitor, then you will need to replace the computer screen.
Dec 29, 2012 | Toshiba Computers & Internet
1999 Honda Civic LX Stalling/Overheating!!!
(I don't know much about cars so bear with me).
I've had problems of overheating previously where my car's thermostat would hit 140. I think I've fixed the issue, I've replaced the thermostat but it was still doing that and 2 hoses blew and needed to be replaced. I've had to consistently fill my radiator with 50/50 antifreeze on a daily basis to ensure it won't overheat, so far that seems to be keeping the peace.
But now as of 5 days ago, I'm experiencing these new issues of stalling. Upon taking my civic into my mechanic, his meter showed that there was a misfire in the 2nd cylinder a month prior and now all 4 are misfiring. He thought it was the head gasket at first. I had just recently replaced the spark plugs with NGK Platinums, new spark plug wires and a new distributor cap.
I've received many possible culprits to my problem consisting of possibly the Throttle Position Sensor, Fuel Filter/Injection, Distributor or a radiator cap. I'm financially strapped at the moment and only could afford the radiator cap which didn't solve anything, however my radiator is running on 80% water at the moment. I'm really at a loss and I feel like I've done what I could and I'm at my wits end. Please help my poor little Civic cheat death for a little longer.
Sep 11, 2012 | 1999 Honda Civic
I'm fixing up a Camaro I bought from a friend and one issue I can't figure out is why the horn isn't working. I've checked all the fuses under the hood and they are all good. When you
the clicking sound you here is the switch get out a test light go straight to your horn have someone hit the button if your test light lights up your getting power next thing to do is to check ground use a ohm meter and check for less then .5 of ohm of resistance any more is bad and you should run a new ground if your still un sure hook the horn straight up to the battery and see if it will go off lol good luck!!!
Jul 09, 2012 | 2001 Chevrolet Camaro
Compaq Presario CQ56-115DX shows a blank screen on boot, but runs perfect on external display
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Mar 24, 2012 | Compaq Presario CQ56-115DX Laptop
I have an lg 52lg50 lcd tv. for some time now the switch just repetitively clicks until the tv eventually comes on. the last couple of days, it doesn't come on at all - it just carries on clicking. is...
Hi, I've had that happen with TVs before, it tends to be caused by blown capacitors on the motherboard. It can be fixed however it's not something you could easily do on your own, you'd want to take the TV to a local repair shop, I've seen the repair range from $50 up to $250 or so in my experience.
Aug 29, 2011 | LG 52LG50 52 in. LCD HDTV
LG ku 990 switching off
  1. maybe you can phone up LG or you can call your network user and ask for help. this may fix your problem.
May 27, 2008 | LG KU990 Viewty
Televison & Video Logo
26 people viewed this question
Steve Allison
Steve Allison
