SOURCE: i need the code for westinghouse tv
I am having the same problem with direct, let me know if you find a solution?
SOURCE: need tv codes to program direct tv remote. \r\nI
Try these codes:070,085,001,126,166,079,120 I hope that helps.
SOURCE: Westinghouse - 60" Class / 1080p / 120Hz / LCD
There is a method called a Power Scan this method allows you to search for all possible codes. Try this until you reach a code that carries all of the functions desired. If the TV mode button starts flashing rapidly during this process you have exhausted all possible codes.
Power Scan
1.) Hold down the clear "TV" button on the remote for four seconds, then press 500 pound ( #)
2.) Hold down the clear "TV" button on the remote for four seconds, press the big power button once.
3.) Press the channel up button once per second until the TV turns off then press pound (#).
Daniel Busa
DISH Network
Customer Service
Testimonial: "Thanks for the tip on the Power scan. I was trying the power scan described on some other webpage and it didn't seem to work. Your tip was dead on "
Hello! I wanted to give you a few more codes that you may not have tried. I also wanted to give you the instructions to the power scan, which will scan the TV for the correct code. I hoep this helps!
Codes:
500
795
719
Power Scan:
1. Hold down the Clear TV button until all lights at the top of the remote light up
2. Press the red TV POWER button
3. Press and release the up arrow on the remote about once a second until the tv turns off.
4. When it turns off, press the # (Pound) button
5. Try powering the tv on/off, and try the volume. If one or more of these functions do not work, start over at step 1 again.
Becki Barned
DISH Network Customer Service
SOURCE: just got a vr-4625.... cant find code for comcast remote..... help !!!!
0178 for remote with grey "OK" button, 11265 for remote with red OK
