There is not one try link page 25.
https://images.homedepot-static.com/catalog/pdfimages/71/71e01a43-c1cd-4b66-8500-d0d8d287bdac.pdf
SOURCE: 50K BTU Reddy Heater Trips Circuit Breaker
If the unit lights Check the photo cell this can be done with an ohm meter and good light. Should have continuity in light.
SOURCE: heater will not run
You don't say, but I am assuming that the motor is running and there is combustion in the combustion chamber and the heater is running fine, then the reset trips. Is this correct? If so, chances are the Safety Control (reset) is defective. Part number HA3003. The photocell could also be at fault. Check for a dirty lense on the photocell.
But---If there is no combustion in the chamber, then the photocell detects a no-flame condition and then it trips the reset.
Troubleshooting tips for a Spark Plug type heater
SOURCE: Reddy Heater Kerosene 50,000 BTU produces TOO
There are2- adjustment screws on the back 1--air---#2-fuel. adjust it while running for the perfect combination for the fuel/ air ratio.!
SOURCE: REDDY HEATER 40,000 BTU KEROSENE&DIESEL
Clean your nozzel, check your fuel & air lines, you may need to replace Spark plug and filters. You can go to the manufacturers website at www.desatech.com and they offer service manuals. I hope this helps you!
SOURCE: i have a reddy heater 60,000,00 btu kerosone
Here are a couple of tips that I wrote that tell you how to troubleshoot aTorpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters
Torpedo Heater Pump Pressure Adjustment
heatman101
Here are a couple of tips that I wrote that tell you how to troubleshoot a Torpedo or Reddy heater...
heatman101
heater...
Reddy
Torpedo
heatman101
heater...
Reddy
Torpedo
heatman101
