Televison & Video Logo
d
dale gonce Posted on Mar 04, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Does element elefw328 have hulu - Element Televison & Video
Level 3:
  • Element Master 6,688 Answers
  • Posted on Mar 05, 2019
Cindy  Wells
Element Master
Level 3:
Answers
6688
Questions
0
Helped
3532148
Points
21745
No, the Element ELEFW328 does not have a Hulu app. This is not a Smart TV and does not support a direct connection to the internet for any streaming service. To get Hulu, you'll need some sort of a set-top streaming box or device. This could be something like the Roku devices, a FireStick or a computer connected to the TV. Connect the device to one of the TV's HDMI port and then connect the device to the your internet (router).
The specifications for the ELEFW328 are available from CNET here: https://www.cnet.com/products/element-elefw328-32-class-31-5-viewable-led-tv/ .
I hope this helps.
1 Related Answer
Jesse Kyle
  • Posted on Jun 05, 2016
SOURCE: How to do a channel setup on a 32" element TV model no. ELEFW328 HDMI .
In the main menu look for the channel settings then you should see auto scan
Can’t get my element tv to network for WiFi my tv is ELEFW328 I have air tv with Xfinity WiFi the other TVs have WiFi help please
The Element ELEFW328 is not a Smart TV. Thus it doesn't have any built-in network hardware (wired or wireless). You will need to add hardware to send the signal from your AirTV to your Element TV via one of the three HDMI ports. You could get the AirTV Play, AirTV Mini, Roku or other streaming box/stick. Set up this device to talk to your wi-fi and then the AirTV. Alternatively, you could try to mirror your Android or iOS AirTV display on your TV. If the device supports MHL (https://www.startech.com/en-us/faq/mhl-compliance) or Slimport, then you need the appropriate HDMI adapter/converter. Otherwise look at the ChromeCast or similar device to plug into your Element TV.
I hope this helps.
2answers
Is there a way to hook an element TV model number elefw328 to the internet
Best way is via pc or laptop or smartphone which has tv or av output (some new sets have hdmi output that will work if your set has hdmi intput.
I have an element elefw328, thevseial number is K140023**********, I have the main board out, shop jimmy didn't have one, eBay has tons how do I identify the important numbers to make sure I buy the right...
Look for the part number on the board and order by that number not model number and you should be ok...what makes you think its the main, on that set power board issues were more common than the main board failing
I have a element 32' tv win i turn it on just gos 2 blue sceen replaced the power bord y please help
you mean no default element power up
or menu settings ?
what happens with the old remote
does that recognize the new printed board
any control buttons in the frame working
do you have the power source working at specs
and the correct replacement circuit board
Element ELEFW328 32" 720p 60Hz Class LED HDTV
Mar 06, 2017 • Cell Phones
I have a 32 inch Element TV model ELEFW328 that will not pick up DTV channels how do I get DTV signal on my TV
Did you go into settings and tune into DTV settings, did the TV look for digital signals ?, if not check out the aerial.
Top Element Televison & Video Experts
matt martin
matt martin
Are you an Element Televison and Video Expert? Answer questions, earn points and help others
