Http://appliancerepairguides.com/whirlpool-cabrio-washer-error-ld/
The weblink may not be to someone in your area, but he makes a good point - the system says the water is draining too slowly and that could also be an issue outside of the machine - is the drain line connected to the house drain clean? Is the house drain clear ? Did you suck up and dry to pump something that it shouldn't?
And as well, like the link suggests, can you somehow hold the Motor shaft on the pump and ensure that the impellor is still attached and moving with the motor shaft - That could be damaged or maybe it could be like a small boat motor where the shear pin is called that specifically - if the motor is getting tied up in weeds, the shear pin does just that and sheers off so that impeller stops moving but the motor is not damaged - could you have sheered off the pin between the pump impellor and the pump motor shaft?
Good Luck
See link:
http://appliancerepairguides.com/whirlpool-cabrio-washer-error-ld/
SOURCE: My whirlpool duet washer indicates "5d"...
take bottom panel off should be 3 to 4 screws and will come off then you will see your drain pump in the middle in the center with a plastick cap you can take off. before you take off get plenty of towels ready because water will come out try leaning unit back until you dont have to hold it then take cap off and clear any debree you find and put cap back on and try running again offen to much debree can damage pump and might need to be replaced!
SOURCE: Whirlpool washer grinding noise when draining
there could be something in your pump.....remove the pump and see if there is not something inside...
SOURCE: Whirlpoll cabrio wsaher won't drain
If this a electrical pump chk. to see if there is an in line fuse if not then take the hose loose to see if the impeller has any thing hung in it or it could be a bad spot on your timer
SOURCE: Washer runs until rinse cycle, then starts making
pull problem code from machine. give knob a turn to wake machine-wait 5 seconds-then hold down start and cancel buttons at the same time. Your problem code will come up.
SOURCE: Whirpool Duet Sport Front Loading Washer is making a funny noise
in the bottom of the washer take 2 screws out take panel off and there should be a round screw off tube make sure something is under to catch water needs cleaned out might have few change in it.. look in your users manual for a catcher to clean cant remember name
