Question about Amana PBH093E35AXAA 26" Built-In, 9,000/8,700 BTU Air Conditioner with 8,500/8,200 BTU Heat Pump,
I have a Amana PBH093E35AXAA and it started to be noisy while it's turned on 2 weeks ago. What's going on?
    New Friend:
    Problem Solver:
  • 9 Answers
Try to bring a technician to check or fixe it there might be wrong inside the components like capacitor diod or even the magnetron
Posted on Mar 05, 2019
    Top Expert:
  • Amana Master
  • 62,046 Answers
SINCE WE CAN NOT TEST IT WE WOULD NEVER KNOW SORRY
3 Suggested Answers
SOURCE:
ftw1952
  • 10319 Answers
SOURCE: I have an Amana model NDG7800AW. A few weeks ago
The roller to the belt tensioner is binding causing to make the warbling noise.The bearing needs to be replaced which comes with the roller. A new belt is advisable as well when replacing. The stalling problem could be also from the belt being stretched or the timer relay is weak
Posted on May 01, 2010
  • 132 Answers
SOURCE: My Amana bottom freezer model
Ah this is an indication that your condenser has become dirty, or blocked, or the fan motor is not working or the air flow is restricted.
The noise is generated when the compressor cycles off and sudders to a stop
Posted on Mar 25, 2011
Amana electric dryer whining when started
Is ther anything caught between the drum and the back of the dryer. run you finger around the back edge of the drum inside do you feel anything caught
Feb 02, 2014 | Amana Dryers
Noisy gear on whirlpool ice maker when the plastic wheel turns against the teeth
The new icemaker is new and should not be doing that - return for exchange.
Nov 24, 2013 | Whirlpool Refrigerators
Buick 97 LeSabre hard start and acceleration issues
Have you checked the catalytic converter? After 20 years they do pug up causing some of the problems you describe
Apr 09, 2017 | 1997 Buick LeSabre
My Amana bottom freezer model # BB20VSE, serial # 0006289684, mfg # P1321301WS has become increasingly noisy when the compressor(?) turns on. This started over a year ago and now is extremely loud. Thank...
Mar 24, 2011 | Amana ARB9058CS Bottom Freezer...
We got an Amana dryer last May 29th, so our warranty is not valid by 2 1/2 weeks. A few days ago I went to start the dryer with the clothes in it and the button didn't go on....what can I do??
I would call for warranty service. If you had a complaint under warranty that was not substantiated, or the problem could not be found, then federal law says your warranty is still good for that complaint. Maybe someone forgot to log your complaint, if you know what I mean.
Jun 20, 2010 | Dryers
May 01, 2010 | Amana NDG7800AW Gas Dryer
Side by side Amana freezer/refrigerator thawing.
The doors not being shut can make it freeze up,Just thaw again and make sure the doors get shut each time and see what happens,just post back details if it doesn't work after thawing
Aug 05, 2009 | Amana ASD2625KE Side by Side Refrigerator
Have trouble with frost build up with Amana with bottom freezer.
could be thermostat or defrost heater or defrost timer.you can check the heater with meters that check continuity.the thermostatis located on top coil and sometimes they will seperate.so look for those 2 things.most likely it will be one of the 2.the defrost timer is most likely good,if you hear your machine turn off and back on then the timer is good.
Mar 09, 2009 | Amana ABB1927DE Bottom Freezer...
Buzzing sound for about 2 months
Compressor was replaced (also see additional comments made).
Mar 20, 2008 | Amana ABD2533DEW / ABD2533DEB / ABD2533DEQ...
Amana PBH093E35AXAA 26" Built-In, 9,000/8,700 BTU Air Conditioner with 8,500/8,200 BTU Heat Pump, Logo
27 people viewed this question
Top Amana Heating & Cooling Experts
Donni Steen
Bill Long
Dennis Boxerman
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
