SOURCE: can i watch tv through my epson projector?
Yes, if your projector has a video input. Connect your projector's composite video input jack (usually colored yellow) to your video source. You said you want to use it to watch TV, so you'll want to connect it to the video output of a video tuner (such as a digital TV converter box) or a VCR with a built-in tuner. Set your projector to the video input and you're good to go! If your only tuner is your television, you'll need to check your owner's manual to see if it has an "output" jack. Some do, some don't. If yes, you're in luck. If not, try one of the other sources I mentioned earlier. Good luck!
SOURCE: How do I connect my ps3 to the Samsung smart tv
For best performance I recommend you connect a HDMI cable from the PS3 to the HDMI input on your TV.
To display the PS3 you need to select the HDMI input on your TV.
SOURCE: I need the codes for a Samsung TV UN55D7000 SMART TV
Visit this site for more details. "Electro-help" is th site name. Type in the site name with hyphen in between words, and open the same site. It have all codes and details.
SOURCE: Can I connect a Gateway MT6920 laptop to a Samsung Smart TV?
Hi gabucks
short answer is yes. You will be looking to use the vga port (which is probably currently used for your monitor. Check for the same connector on your tv. Hope this helps.
SOURCE: How can I watch my ultra violet movies on samsung smart tv d8000 and f8000
You can't see this by Samsung Smart.
