SOURCE: ps3 wont play my widescreen dvds on my 108op hdtv
im not sure,but i think you have to use hdmi cables to view in 1080p
SOURCE: widescreen tv=widescreen movie still have black on top & bottom
Sorry, you didn't provide enougb information for anyone to accurately answer your question. The most important thing you omiited was the nature of your video source. If anyone does answer this, I assure you it will be a wild guess. Here's my wild guess:
Your HDTV has a widescreen aspect ratio of 16:9. For every 16 units of width, there are 9 units of height. That ratio matches the exact ratio used in widescreen television broadcasting. However, most feature films (movies) on DVD have an aspect ratio of 2.35:1 or even wider than that. These films will display with horizontal black bars at the top and the bottom, so that you can see the full image. Unless you choose to use one of your TV or your DVD player's options to zoom or crop the image, the bars are 'correct' and there's nothing wrong.
Another possibility is that you have not configured your video source, such as a DVD player, to 'know' that you have a widescreen TV. Nearly all DVD players ship configured to output using a NON-widescreen aspect ratio, so you must adjust this setting using your player's setup menu. The same is true for most cable boxes and satellite receivers.
Finally, just because your TV is widescreen, the video source itself may not be. Most standard-definition broadcasts are NOT widescreen, for example.
If you re-post your question with adequate information about which video source exhibits this problem, I'm sure you will get much more specific and helpful answers.
SOURCE: Need code for Viore TV to program LG RC897T DVD/VHS Recorder
I believe Viore is the same as Samsung. I only noticed this by accident as I bought a Viore TV and my friend bought a Samsung and I noticed both remotes were identical. I tried the Samsung codes and the remote worked. Good luck! Kevin
SOURCE: my compaq laptop is stuck on widescreen mode, how do i fix it?
Right-click an empty place on the desktop
choose properties
go to the settings tab.
Then just follow this
Let us know if that works. If not we'll try something else.
Best of luck!
