SOURCE: Kenmore / GE side by side defrost drain keeps freezing up
Check under the base, the tube must be clear to the water tray, often there is a rubber flow restrictor, this either perishes or blockes, either way remove it, defrost over night and then turn back on, should then work ok within 24hrs. Regards Adbvisor
SOURCE: GE side by side refrigerator defrost problem
CHECK THE DEFROST HEATER FOR CONTINUITY. IF IT IS O.K. CHECK THE ELECTRONIC CONTROL FOR A FAULTY SOLDER CONNECTION ON THE DEFROST RELAY. THE ELECTRONIC BOARD SHOULD BE LOCATED ON THE BACK WALL OF THE REFIGERATOR BEHIND AN ACCESS PANEL.
SOURCE: Defroster cycle stuck
Unfortunately GE has been having a problem with the main mother boards on your model refer, the mother board controls the defrost cycle and there is not reset for it, you may have a bad board.
SOURCE: Long run time between defrost cycles
You have a broken defrost part. Either the heater, t-stat or timer. The longer you let it go without repairing it, the more parts is take out.
SOURCE: GE Profile Refrigerator defrost cycle last hours
it;s probably not going through the defrost cycle or its getting stuck in defrost .. on the back of frig the is a metal cover plate . in side you will find the main board . replace it . it runs the compressor and defrost and controls tempt . this is a very common problem . the new boards are better . and they cost a litle more . mm hope this helped / feed back pls .
