Hi, the crackling noise means it needs a service, was it stored in a shed or garage ? As damp storage is the likely cause.
As far as i know it was stored in a storage closet. When i opened the unit up, it was filled with dust and spiderwebs. I don't think there was access to any moisture to the mixer but I can't guarantee that.
Would it be possible to somehow do some DIY maintenance? We don't have any certified Mackie dealers where i live. It's extremely difficult to get any piece of equipment "professionally" fixed here.
SOURCE: Trying to connect a PMP300 to 2 passive speakers.
Check that the slide switch is up in the MAIN L and MAIN R position.
Check that the PAN pots are all CENTERED.
SOURCE: I have recently acquired an
The speaker connections are on the BACK and are "Speakon" connectors... These are special plugs and these apparently can also accept 1/4 inch plugs. It appears that the MINIMUM impedance should be no less than 4 ohms, NOT 2 ohms. One of the back connectors is for the mains, the other ois for the monitor soeakers. The FRONT connections are line level which doi NOT drive speakers,
SOURCE: hey, i bought a new
I have a 412 speaker that works good at low volume with simlple set up when key boards turn up on mixing board the red peak light comes on and speaker shuts down i think its a protective shut of for overload but very easily triggered have to work with material too find a solution can any one confirm this shut off phenomena
