SOURCE: my canon clc 2400 i9s dropin toner or starter
I---YOUR HOPPER COULD BE BAD, THE HOPPER DRIVE BELT COULD BE WORN OUT, IF ITS THE DEVELPOER THEN YOU NEED TO CHANGE YOUR DEVELOPING ASSY. YOU NEED TO BE MORE SPECIFIC WHERE IS THE TONER GOING ON THE TRANSFER ASSY. OR THE GROUND HOW ABOUT YOUR QUALITY
SOURCE: where is waste toner on kyocera 1820
TO empty the waste toner on a KM/CS 1820 you have to remove one of the side covers from the drum unit on the machine and vac out the old toner i've had customers try to reuse the toner please do not do this. just vac it out good and your normaly good to go!!
SOURCE: Error E31
this is an error code for slow warm up you should pull the fuser out and check the thermistors and condition of the rollers. sometimes the thermistors get caked in toner so they cant read the temps correct. if you take the unit apart you should be able to detect the toner build up. a soft clothe and some WD40 may be able to clean it off but be ccareful as too rough may clip ther resistor off.
Waste toner reservoir overflow problem (when the total number of copies is 100 thousand sheets or more)
• After E31 is displayed, 1,000 sheets are copied. Or waste toner exceeds 5 g.
Defective waste toner sensor or engine board (KP-5061).
Shake the process unit from side to side and turn the power switch off and then on. If the problem cannot be solved, replace the process unit. After replacing the process unit, turn the power switch off and then on. If the problem
cannot be solved, replace the waste toner sensor or the engine board (KP-5061).
I hope this is helpful,
Shawn
