Question about Janome Sewing Machines
Janome My Excel 23X how to get the front off?
The stitch length slider has almost ceased up and is nearly impossible to move. It seems like it's just the old grease solidified but I need to remove the fascia of the machine to inspect which part of the mechanism is so stiff? I have loosened/removed all the obvious screws but the fascia still seems attached. How do I remove the fascia or free the stitch length slider control? Thanks in anticipation Dave
SOURCE:
bargainbox
  • 1388 Answers
SOURCE: My Janome my excel 23x
Ensure that all is clean and free of lint jams....now for tension troubleshooting .......
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tension to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your
projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with
a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to
disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean
the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
4c76dc1.jpg ...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all
back properly.
165ca5c.jpg FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is,
and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine
case....no case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistent diameter with good thread, and less compensating to be done by your tension plates and less thread breaks !
If you want any more help with this, just post back here, or, drop a line through the "Contact Us" page at www.bargainbox.com.au
Posted on Apr 25, 2008
  • 1116 Answers
SOURCE: I have been given my mums janome my excel 23x
This is as close as I can find - http://www.sewusa.com/Threading_Diagrams/Threading_Pages/New_Home_Threading_Diagrams/New_home_2022_Threading_Diagram.htm
Check with local shops that sell this brand for an owner's manual as there is more you need to know about to use this machine.
Posted on Feb 20, 2010
Testimonial: "Thats exactly what I neeed, thanks thanks and more thanks...Trish"
SOURCE: My Janome Excel 23x will not reverse. Any
mine had the same problem... If you can take it apart...the part that should slide back and forth inside just needs to be oiled with machine oil.  Slide it back and forth a couple of times after oiling it and it should start to work,
Posted on Apr 14, 2010
hazelgrace
  • 340 Answers
SOURCE: lost my sewing instruction manual when moving
Hi
You can download some partial manuals from the Janome site.
This is for the Janome D'cor Excel Pro 5124:
http://content.janome.com/documents/File/ManualFile/DecorExcelPro5124.pdf
Which should be similar to the ohter model number you mention.
Hope this helps!
Posted on Nov 16, 2010
bargainbox
  • 1388 Answers
SOURCE: Hi, how old would a janome my excel 23x be & being
23X is getting on 20years...the 18W is still current model and an EXCELLENT machine....go for it !
Posted on Nov 13, 2011
Janome My Excel 23x threading, stitching, tension problems. Sometimes I get the machine going for a while (with great messing about) then it all goes awry again.
when anything gets frustrating to use and is costing money , the idea is to junk it and get a new one
Buying brand name is not wise as what was good long time ago can now be rubbish
I would suggest that you spend time going to dress making meetings and get an idea from the rest as to what would be a good machine to look at
Price is not a criteria for quality, neither is weight
The major criterias should be how often it has to be repaired , parts accessibility , ease of personal maintenance and lastly the availability of a workshop manual to carry out minor adjustments
Oct 06, 2018 | Janome Sewing Machines
New home excel 23x
New Home is one of those machines that has multiple families. I have one that was made by White, and yours appears to be made by Janome. I hope that information can be helpful int he future.
Does the slider seem to be bent in any way? If not, the insides of your machine may be full of bits and pieces of fuzz, lint and thread,, thus forcing the lever to the far right position. I have had that happen with mine. It had to be taken apart and cleaned. I hope you get it going soon! There are some independent repair shops that don't charge a king's ransom for machine repair. I hope you are sewing again soon!
Dec 08, 2013 | Sewing Machines
Lost my sewing instruction manual when moving house. Can't remember stitch patterns adjustments. Need a new sewing manual for my Janome Decor Excel 11 5024 Thank you
Hi
Hope this helps!
Nov 16, 2010 | Janome D'cor Excel Pro 5124 Mechanical...
Feeddog isn't working
your stitch length may be set to zero
Apr 09, 2010 | Janome D'cor Excel Pro 5124 Mechanical...
Came without an instruction manual
You should be able to buy an instruction manual from Janome or even on ebay.
Jan 21, 2008 | Janome D'cor Excel Pro 5124 Mechanical...
Sewing Machines Logo
43 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
