Hello, please advise, I have completely stopped working on the Pioneer VSX-520 Receiver This is the only combination of buttons. The receiver clicks on it to turn on the display, and in 3 seconds it goes out, dead. ADV SURROUND + STANBY / ON the relay clicks, the display is dimmed, and the VOL 56 and the click again and the receiver is dead. Does anyone please advise what's behind the problem?
Hello Dugen, obviously you have a problem in the function stage, it may be missing a voltage or you can have voltage leaks in the output amplifiers, you should check it with the service manual, if you have the knowledge and if not you have to take it to a specialized technical service
Hola Dugen, evidentemente tienes un problema en la etapa de funciones, puede estar faltando una tensi?n o puedes tener fugas de tensi?n en los amplificadores de salida, tendr?as que chequearlo con el manual de servicio, si tienes los conocimientos y sino tienes que llevarlo a un servicio t?cnico especializado
SOURCE: Pioneer VSX-4900S Receiver Connections
I know this is an old post but run front speaker outputs to the inputs on the sub then from the sub to the front speakers. bam!! it should work
SOURCE: Lost remote controller of Pioneer VSX-D506S
You can buy Original Pioneer Remote from HERE for VSX-D506S
SOURCE: Pioneer VSX-D411 receiver "Amp Error" message
Unfortunatelly your receiver has failed. The front panel is telling you one of the power modules is probably bad. Not an DIY type of repair. These parts are near $40.00, plus cost of replacing.
Look at options to replace your trusted receiver with a new one.
Good luck
SOURCE: pioneer VSX-3800 shuts off
I have this same problem mike. have you founf any solutions yet?
I have a heck of a time turning my reciever on and when it does turn on I try to change the channel only to have my unit shut off on me! any help would be great.
[email protected]
SOURCE: Problem for Pioneer VSX-818V-K 5.1 Channels
Test with an surround sound media ie. Blu-ray or DVD)_. Disconnect the front and all other speakers that are working to see if sound from the missing speakers are heard. If this doesn't work then start by tracing and checking all the wires from the receiver to the speakers for bad/shorted/open connections.
PLEASE VOTE IF THIS WAS HELPFUL. THANKS & GOOD LUCK.
