SOURCE: I have a Plymouth Grand Voyager Mini-van. 3.3
Have you replaced the plug wires? If they have too much resistance they can cause the coil to fail.
SOURCE: The Compressor on my Maytag M7DH65B2A quit
This is a common problem with most dehumidifiers, not matter who the manufacturer is. The best way to prevent it is routine maintenance. Especially when you stop using it for the season. Dismantle it and clean the unit thoroughly. Putting a light coat of WD40 on the coils and contacts will help abate corrosion during the off season. If you are in an area where you use the dehumidifier continuously , then you should step up your routine maintenance to every 6 months. Cleaning the filter regularly, will help expand the dehumidifiers life span. By the way, the model you listed was manufactured by Fedders for Maytag.
Keep up the routine maintenance.
SOURCE: e-21 is on the panrel
Try turning the power off and back on a minute or so later your clock may reset
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
