Hello Richard, if your Bose Acoutimass 5 Series II, are compatible with your Yamaha RX-V379, using them in the L and R Front outputs of the Yamaha, this set is prepared to work between 10 to 200 watts of power, your Yamaha delivers 70 watts per channel, what is within the range of work of the Bose
I am sending you the link so you can download the Bose guide
I hope you enjoy the Yamaha-Bose convention
Greetings Franco Dosil
Hola Richard, si tus Bose Acoutimass 5 Series II, son compatibles con tu Yamaha RX-V379, usandolos en las salidasL y R Front del Yamaha, este conjunto esta preparado para funcionar entre 10 a 200 watts de potencia , tu Yamaha entrega 70 watts por canal, lo que esta dentro del rango de trabajo de los Bose
Te estoy enviando el link para que puedas descargar la guia de los Bose
Espero que disfrutes de la convinacion Yamaha-Bose
Saludos Franco Dosil
https://www.bose.es/es_es/support/products/2_speaker_home_theater_support/am5_series2.html#SupportTabs_tab0
SOURCE: Just purchased the Yamaha RX-V765 receiver. Have
I too have purchased the same receiver and have the same speakers. Did you get a good solution to this problem and how does it sound?
